I have random misfires (usually while decelerating or under low load, rarely at idle), very rough idle 20 seconds after pulling up, no limp mode issues at WOT but engine takes a while to crank over in the morning... I have replaced the spark plugs, ignition coils, fuel pump, fuel filter, front o2 sensors, PCV valve, fuel injectors, as well as doing a carbon clean, compression check and vacuum smoke test with no luck.
If anyone has any ideas on VCDS which could help with diagnosing the cats I would greatly appreciate it... my car passed all of the readiness test on VCDS and I don't get any codes EXCEPT for "throttle body actuator" and "throttle body malfunction" when I reset DTCs and adaptions.
My cat temperatures are normally quite close to my exhaust temperatures, I have shown graphs in the excel linked below... and it appears that my bank 2 cat voltage jumps around a lot more than the other (as shown on chart below), which fits in with the higher LTFTs I get for that bank... and when I decelerate the front o2 lambda goes to 4 and the rear o2 volts goes to zero (should the rear o2 voltage hit zero this much?)
AT IDLE
WHILE DRIVING
All of the data I have logged is in the document below which outlines the various parameters (inlcuding misfires) at 1. IDLE, 2. NON-STOP DRIVING, 3. DAILY DRIVING
https://drive.google.com/open?id=0B2...FJzX1ppSnRFOEU
If anyone has any insights for me I would great appreciate anything
