Results 1 to 3 of 3
    Aug 17 2015
    Modded 06 Maxima, 02 Civix EX
    Stockbridge, Ga
    Electrical Issues
    So I changed my BCM (8E0 907 279F) with another BCM (same code) because it was smoking through the ground wire evertime I attached the ground and put it under a load and i had no lights, horn, wipers, etc. Now my lights and wipers work but my horn goes off as soon as I turn the key in the ignition. Is there some kind of programming that has to be done when swapping the BCM?
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    Quote Originally Posted by RigDotCom View Post
    I think it's module 81 that you have to code for adaptation to your VIN. VCDS should prompt you what the key is to adapt.
    Edit:
    Channel 081: Component Protection
    To start the process of Vehicle Identification Number (VIN) learning, enter/save 46992 as new value.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Aug 17 2015
    Stockbridge, Ga
    OK, I'm in the process of buying a Ross-Tech cable now. Will do, thank you.
