Results 1 to 3 of 3
    Jan 12 2016
    Los Angeles, California
    Is the Ross-Tech Micro-CAN Interface the right VCDS dongle for me?
    I was looking into doing a few VCDS/ VAGCOM changes, so I started looking on Ross-Tech's site. I saw that the 2 enthuist oriented products for the 8v give this notice:
    "As of April 15, 2016, we have learned that some 2016 and newer MQB based models may contain certain modules which are not accessible with the Micro-CAN."
    Does anybody know what modules are not accessible?
    Is this the right one or should I get the Hex-USB?
    Thank you
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Mar 15 2016
    If your only looking into doing a few vcds changes I would get the OBDeleven module.
    It's way cheaper and does the majority of what the ross-tech can do. https://www.youtube.com/watch?v=pUvmvN-pZr0
    It only works with android at the moment but as the video brings out you can get a cheap android tablet to use it.
    Senior Member Three Rings gamegenie's Avatar
    Aug 04 2014
    Quote Originally Posted by oblique View Post
    This is dope info right here, I just ordered one.
    I realize that the High-Beam Assist is possible through VCDS if you have the Active Lane Assist, for $60 this OBDeleven part seem like a steal.
    2015 Audi A3 2.0T Quattro
    2012 Hyundai Sonata GLS
    1996 Jeep Grand Cherokee
    1996 Hyundai Elantra GLS
