Results 1 to 15 of 15
Thread: No power at WOT
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    No power at WOT
    Any thoughts on this?
    Normal acceleration is fine...all the way up to 100mph that I've tested. But if I stomp on it, in any gear, the car goes to redline but does not accelerate. Back off throttle and all is normal at the prior speed; stomp on the gas again...no power to the wheels just goes to redline. Most noticeable at highway speeds and no where near the governor.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    manual or auto ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 27 2014
    Park City, UT
    Manual
    Oct 09 2008
    I would guess your clutch is slipping but if you keep doing it I think you would have also noticed a smell.
    The Awesome™
    Oct 27 2014
    Park City, UT
    Even if the clutch is out and in gear? Does not slip during "normal" operation and only when in gear. i.e. Cruising along at 65 in 6th gear, floor gas pedal and this happens.
    Nov 10 2014
    Apex, NC
    what car is this?
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Quote Originally Posted by d1amund View Post
    That's usually when a slipping clutch first shows its symptoms, it will eventually start to slip in low gears.
    Where is the clutch bite point?
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    How many miles on the car and tune ?
    Could be tranny over heat safety due hot whather 90-100F
    Edit: you could try to flash TCU and see if it's helps
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Oct 09 2008
    If the clutch is engaged, the car is in gear, the rpms are rising, and the car is no accelerating then yes the clutch is slipping. There is nowhere else for that power to be going that wouldn't involve loud noises or a lack of ability to move at all.
    Jan 09 2010
    New York
    Quote Originally Posted by UkuRiSh View Post
    Manual my bad! Dafanatly need new clutch.
    Oct 27 2014
    Park City, UT
    Yep, it was the clutch slipping, but not due to clutch failure per se. Was a friends 2015 A5 with 16k miles. Audi found something failed in the transmission which caused oil to leak into the clutch...hence the slipping due to an oil soaked clutch disc. Car had to have a new transmission and clutch installed. One dealer denied warranty...stating and I quote "the clutches in these newer Audi's are made less forgiving so they are easier for people to drive". Translation...we don't put quality components in our cars. Another dealership took it upon themselves to dig in and figure it out before placing blame on the owner.
    Nov 10 2014
    Apex, NC
    your friend should write AoA telling them how one dealer was quick to dismiss and the other went out of their way to satisfy the customer
    Present:
    Veteran Member Four Rings Hippiekiller's Avatar
    Nov 15 2014
    Las Vegas, NV
    Let me guess, Audi of Las Vegas denied. Henderson fixed.
    Oct 27 2014
    Park City, UT
    Quote Originally Posted by Hippiekiller View Post
    This was in Salt Lake City. Strong Audi denied. Audi Lehi fixed. I ran into similar bullshit years ago when I lived there with Strong denying warranty and had to have a regional service manager step in and crack the whip...seems it's business as usual.
    Nov 15 2014
    Las Vegas, NV
    Ahh, gotcha. Have had similar issues in Vegas. I go to Henderson for everything now.
