Results 1 to 9 of 9
    Jun 02 2012
    CO
    Mirror Tap issues
    Hey all,
    So a little over two weeks ago I got into my car to find that my MMI system was non responsive. The screen didn't flip up, and all of the buttons were not illuminated or responding to any input. I assumed this was a blown fuse for some reason and thought it would be no big deal. Turns out the dealer disagreed and thought otherwise.
    I was told that the mirrortap that I had installed for my V1 was the reason that the fuse blew. However, before making this determination, there was a TSB out about the 5F control module possibly being the issue. So they replaced the entire control module. Unfortunately, the fuse continued to pop after they had done this. They located the mirrortap and removed it which in turn stopped the fuse from popping again. They covered the control module under warranty, but asked me to pay a couple hours labor as the whole project took them two days to sort out. Not terrible but I wasn't happy having to pay for anything related to this at all.
    So, anyone had their mirrortap do something similar? Any thoughts on why this would be happening? I am tempted to plug it back in and see if it happens again... But everything has been fine for a few days now since it had been pulled out so I feel like it may not be worth messing with. Might just have to go the long way around and run the power down the A piller to the fuse box and install a dedicated fuse for the V1.
    2021 Audi RS6 Nardo, CCB, Carbon Fiber package, Red Star Resonator Delete, IE Intake, IE Stage 1, Euro cup holder
    2020 Audi SQ7 Daytona Gray Pearl,
    Gone:
    2012 S4 Brilliant Black
    2016 S6, Daytona Gray Pearl
    2014 SQ5 Moonlight Blue
    Senior Member Two Rings InvigR8's Avatar
    May 18 2009
    Audi R8 (2017 V10+, 2008 V8), RS 7, B8 A4 Avant, A6 Allroad 4.2, C6 S6 5.2, Ur Quattro
    Los Altos, CA
    Do you have HomeLink? I thought that was a different fuse from the MMI.
    Veteran Member Three Rings bobamoo's Avatar
    Jul 15 2014
    Greensboro, NC
    I had a stereo shop install the wire down the A pillar. Not sure where they connected it but have not had any issues.
    Feb 11 2013
    C7 S6
    North San Diego
    I would say just run it down to the fuse box, it's probably a 15-20min install, you just need the hardwire kit and an add-a-fuse.
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Mar 14 2016
    Cleveland, OH
    I run the MirrorTap on mine no issues. I checked everything with a multimeter. Might be a bad mirrortap though...
    Jul 01 2016
    Orange County, CA
    I had that exact same thing happen. Was being careless during install trying to re-use an old cord. Got the exact same outcome. Was a blown fuse in the fuse box in the trunk. Replaced fuse, got new cord and installed without issue. There is a thread on a write-up for which wires to use, my guess is you didn't have it installed correctly.
    2016 S6 Premium Plus Dakota Grey/Arris Red - Sport, Bose, LED, Black Optic, APR Stage 1 ECU & TCU upgrade, Roc-Euro intake
    2016 SQ5 Premium Plus
    Jun 02 2012
    CO
    Quote Originally Posted by CASoxFan View Post
    I ordered the correct cord, used a multimeter, and followed that write up that you are referring to. My only thought is that it was a bad mirrortap and that's what blew it.
    Gone:
    Mar 18 2011
    Denver
    If you have a set of trim tools, running it down the A pillar to the box is a 3 minute ordeal.
    Junior Member Two Rings
    Jun 03 2014
    Glendale, AZ
    Quote Originally Posted by yas View Post
    I have a 2014 A7 - what fuse did you tap into when you ran it down the A pillar? I bought mirrortap for my V1 but I have not yet installed it.
    I appreciate any suggestions - thanks,
