Results 1 to 38 of 38
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Resurfacing Pressure Plate
    Has anyone resurfaced an oem s4 or rs4 pp? I plan on using the rs4 pp from my Vast clutch with a new 6 puck disk and TTV FW. I don't want to buy a new pp if I don't have to.
    Thanks boys and girls.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp Package
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    I'm also interested in knowing if this is something that can be done.
    I currently have a FX400 on a stock (possibly failing) DMFW. I have a TTV Flywheel sitting in my garage. If I get another 6 puck disc will I need to do anything to the pressure plate? What about moving from a 6 puck to 8 pad from CM?
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I think it is tough because they have to rig up some way to hold the friction plate steady while they cut it.
    Ive have a south bend resurfaced before, but never an oem. Pretty much just need to find a decent machinist that is willing to do it. Not sure what they would charge (my guess ~100) but might be close to just buying a b7 rs4 rep set.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Feb 23 2010
    Emmaus Pa
    I design surgical instruments for a living and we have a badass machine shop in our building. I can 3D print something to hold it, just not sure the best way to do it. I could have them throw it on one of our 5 Axis DMGs and hold it firm, then just have the tooling do the work. Wouldn't have to rotate the pp.
    B9 S4- EPL/AWE
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by CELison View Post
    There are machine shops that can do it correctly. Not all can.
    Of course you better make sure your DMFW is still good before spending money on it.
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Unless there is a noticeable lip that needs to be machined away I would just use this guy.
    http://www.brushresearch.com/brushes.php?c1=6
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by NOTORIOUS VR View Post
    I have a new ttv fw
    B9 S4- EPL/AWE
    Jan 29 2009
    I have a new ttv fw
    Derp... for some reason I continued to think you were resurfacing the OEM FW.
    for the PP, be careful about the SAC mechanism!
    Feb 23 2010
    Emmaus Pa
    You mean breaking the plastic tabs the springs ride on? Or just resetting it?
    B9 S4- EPL/AWE
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Pressure plates generally do not get resurfaced. As others have noted, it is tough to get the PP to hold still. Buy new or simply reuse.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 23 2010
    Emmaus Pa
    I'll probably get the flex hone for rotors and flywheels and use that.
    B9 S4- EPL/AWE
    Oct 27 2011
    TOYS
    Philly Suburbs
    South bend will do the work for you, not sure if its worth the shipping cost/time/hassle though.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Also consider step height - I guess the SAC mechanism could pick up the slack.
    Personally, I would get a new PP. Weak plastic SAC on B5 PP plus you're building for more power. Motor pulls are not that bad and you've got experience there, but even if you could R&R in 1 day, you need to consider the value of your time.
    Feb 23 2010
    Emmaus Pa
    SAC mechanism will take care of the step height. I plan on just hitting it quick with the flex hone. My clutch set up is OEM RS4 PP/ 6 puck disk/ TTV FW. That should hold the power fine. Motor is already out of the car and has been for some time. I just don't feel like buying a new PP if I can referb this one.
    B9 S4- EPL/AWE
    Oct 27 2011
    TOYS
    Philly Suburbs
    FYI, I really doubt that clutch will hold during aggressive NLS if you have that in mind while running alky cocktail.
    Feb 23 2010
    Emmaus Pa
    I don't have that in mind no. I never used NLS
    B9 S4- EPL/AWE
    Nov 16 2010
    WetSide, WA
    Luk b7rs4 repset from ra for $137. Prob bolt on and go with that fw and disk, but I would cycle it in the press to make sure.
    Ive got a pp here if you want to swing by and mock it up to see what it looks like.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by zillarob View Post
    I might just take you up on that.
    B9 S4- EPL/AWE
    Nov 16 2010
    WetSide, WA
    Shoot me a pm if you want. Right off the tp in Morgantown.
    Feb 23 2010
    Emmaus Pa
    The B7 PP just needs the bolt holes drilled to work with a B5 s4/rs4 FW pattern? Want to just put my whole car together?? haha.
    B9 S4- EPL/AWE
    Nov 16 2010
    WetSide, WA
    With that fw and disk, good chance that is all it needs
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Just the 3 dowel pin holes, well that or drill the flywheel for larger pins, etc. Not sure if the b5 TTV flywheel for the standard b5 clutch needs some of the pad removed or not due to the pressure plate having a rivet location causing some interference. I just got done putting the b7 rs4 plate on a stock flywheel using 2mm spacer washers. I don't expect any issues.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Feb 23 2010
    Emmaus Pa
    Rob, Can I come by with my FW and mock up that b7 pp? I'll just grab one off rock auto if everything goes together fine.
    Edit: for 135 bucks I just bought the LUK b7 rs4 clutch kit.
    B9 S4- EPL/AWE
    Nov 16 2010
    WetSide, WA
    Ya, for 137 its pretty much a no brainer
    Ill be down in ac for a race this weekend, but any other time is good.
    I should have everything we need, except the beer
    Feb 23 2010
    Emmaus Pa
    I'll have the B7 PP soon so I'll be able to mock it up in my garage. Seems easy enough. Now if you want to put the whole car together I'll buy you a truck load of beer like smokey and the bandit. This car needs to run again. I miss it.
    B9 S4- EPL/AWE
    Veteran Member Three Rings MyXbfS4's Avatar
    Jan 18 2015
    2000 B5 S4 Light Silver w/ Onyx (no sunroof), 2009 A4 Black
    Los Angeles, California
    this kinda brought a tear to my eyesince it'll be a while before I get mine back. I'm super excited to see your car in action. your build thread is one of the first threads I sub'd after joining AZ so its awesome to see you didnt give up on it
    2002 Laser Red B5 S4 Sedan
    2011 Ibis White B8S5 4.2V8 Coupe
    2000 Silver B5S4 6mt Sedan(no sunroof)- SOLD
    2001.5 Silver B5S4 6mt Sedan stg3- RIP
    2000 Santorin B5S4 Tip Sedan- RIP
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    In case it helps, I went through some of the B7 RS4 PP fun on my A4 (which uses a FW compatible with S4 clutches, like your TTV flywheel). Granted I also used the B7 RS4 clutch disk, but similar principles apply. zillarob was a huge help to me too.
    http://www.audizine.com/forum/showth...1#post11277600
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Feb 23 2010
    Emmaus Pa
    I'm probably going to bring my FW and clutch over (he's local) just to have another set of eyes on it. I'm a little rusty, haven't worked on a b5 in over a year.
    B9 S4- EPL/AWE
    May 16 2008
    South Texas
    i spoke with Southbend about this and they actually remove the friction surface, resurface it and then replace the pressure spring as part of their rebuilds. They said they won't just resurface a pp normally as the spring pressure degrades over time.
    Nov 16 2010
    WetSide, WA
    Thanks for checking Scotty
    The one I sent in was a stg3e so still looked pretty much new because of the kevlar.
    I wondered why they even cut it, but the spring thing makes sense.
    Established Member Two Rings 01Noggy's Avatar
    Nov 26 2012
    BMW e36 M3
    United States
    +1 for southbend. I took a trip down to their shop and everyone was awesome. Gave me and a buddy a tour of the building and everything. Somehow I ended up with a custom clutch kit for my build but they also resurfaced my oem DM and rs4 PP
    Broke Flight Student Built 3L rs6/k24 hybrid on e85
    Feb 23 2010
    Emmaus Pa
    I ended up buying a b7 rs4 pp. Going to Rob's tomorrow to mock it up with my disk and fw combo.
    B9 S4- EPL/AWE
    Feb 05 2014
    BROOKLYN
    If you don't know what you are doing when trying to put this combination together, you will end up taking your transmission down more than once until you get everything situated. "Food for thought".
    Also, why would anyone buy a factory b6 s4/b7 rs4 factory 2200 lb clamp load pressure plate for a bult car, when everyone knows that jhm and ACT has a 3100 lb clamp load pressure. Plate on the market for the b6 s4. But I'm sure you already knew this!
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    ^The ironic part about the most recent post is that JHM and AMD both use a B7 RS4 pressure plate in their clutch kit. The exact same thing the OP got for $137. Only difference is the disk but that can be easily solved.
    Plus I'm pretty sure Jesse and Rob know what they're doing as well. But what do I know ;)
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Nov 16 2010
    WetSide, WA
    Lol, I did such a good job on mine I had to do it twice.
    I used a b5 disk and found out the hard way it needs a little grinder love to work with the newer style pp
    Mine is jhm fw, rockauto b7rs4 pp, and homebrew jhm stg4 disk. Im stoked on how it drives and seems to be holding up.
    We will mock Jesse's up and cycle it in the press to make sure it is good.
    I like to set them so the sac just barely clicks with a full stroke so I know it isnt too tight, and also not wasting a bunch of the sac range of adjustment.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Quote Originally Posted by slow ride View Post
    Nice . I think I will try this
    Sent from my SM-G930T using Tapatalk
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Wagonholic View Post
    AMD says the B7 RS4 PP they use is modified for 3200 lbs clamp. That's quite a bit more than the stock PP.
    Nov 16 2010
    WetSide, WA
    I dont know that jhm mods them, I cant see it anyway.
    Amd changes the dowels and maybe cuts the friction plate so it works with b5 fw.
    They also mod the lever points on the friction plate for more leverage.
