    Jan 28 2016
    San Mateo, CA
    GoPro setup and positioning
    Hi folks,
    What does your GoPro setup look like? More importantly, what are good camera positions (inside and/or outside the car) to get a good view that helps me see and work on my line on the track? What are good positions that produce good looking footage? And are those two compatible?
    Also, what's your setup for capture good sound?
    From GoPro footage, how easy is it to overlay data captured by something like Harry's laptimer? Can it take any video and overlay data (with some manual synchronization, I suppose?), or does the video have to be capture by the app on the phone?
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    i use an ECS headrest mount.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    Get some ram mounts from amazon. though they can still be a little shaky.
    Read the forums and the documentation on Harry's website. It does do overlays and works with gopro. I've never used my gopro with harry's myself. I have a couple of iphones I use for the purpose instead.
    Do a search on this forum for microphones. A bloke on here posted about what he used...
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Quote Originally Posted by MattboyR32 View Post
    I used a ram mount this past weekend on rear passenger door very low near the wheel and i was doing 120+ at times and it seemed just fine.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Nov 28 2006
    Quote Originally Posted by FastEddie View Post
    just depends on how long your arm is from the mount to the camera. the one I use through my front windscreen is a bit shaky.
