HI,
I just completed a thermostat removal and replace on a 2009 A6 with the 3.0T engine. There are a couple of nice write-ups on here and the process was more time consuming vs. high level skills. That is until I went to bleed the coolant system by loosening the PLASTIC bleeder screws/bolts on the supercharger. One came out nicely, the other decided to snap off just beneath the top cap, leaving the balance behind in the threaded hole. Why use a plastic piece on such an expensive automobile versus going with a stainless or brass one?
Below is a post that I had placed in the S4 forum on the thermostat replacement walk-through. I also wanted to have it here to get some feedback from other A6 people and to also have it in here for future reference.
__________________
I was able to complete the thermostat changeout this weekend. Didnt have to remove the water pump pulley and was able to wiggle the t-stat in to place.
Only issue was when trying to remove one of the SC bleed bolt, one of them snapped off. The screw is made of plastic (why?), and trying to use an easy out didnt work. Eventually, I was able to use a tap drill bit and turn it by hand to clean out some of the plastic at the top of the hole. This allowed the lower thread portion to come free from the side of the SC threads, but then the lower portion fell in the SC. Because I had used the easy out which removed the center and then the bit took off most of the top, I dont think much of the plastic went in.
After removing a few small plastic leftovers from the side threads, I was able to thread a stainless M8-1.0 bolt a portion of the way in the SC bleed hole. I met some resistance and didnt push further. The bolt is probably in about 3 turns. I was able to start the engine and the bolt held the pressure without leaking.
A few questions:
- Will this small plastic portion from the previous bolt cause any issues in the cooling system?
- Can I use a thread tap to clean out the bolt threads so I could screw in either a new plastic bolt? How to keep shavings from falling in, I am not sure how many threads need to be cleaned.
- Is the stainless bolt ok to use in place of the plastic? If yes, should I use threadlock and place a rubber o-ring at the top?
- Would the stainless bolt work to "straighten" the threads?
Thanks
