Results 1 to 8 of 8
    Aug 12 2015
    Minneapolis MN
    Vote: Replace / Rebuild damaged front Caliper or just buy a BBk kit
    Cooked my front caliper pretty good at a track event last week. (pads worn to metal on metal). Front caliper paint stripped due to high heat as well as piston boot essentially ripped of. I am having a hard time deciding whether to rebuild or replace front caliper or just say screw it and buy a Stoptech BBk kit. Sad thing is Audi wants $100 just for a rubber boot...lol. (aftermarket is $80). That same caliper repair kit for any other car is $8 dollars. A new Caliper is $400 ($350 aftermarket). I know this is kind of a rhetorical post as everyone here will most likely say "just spend the extra $1,800 and get the BBK. However the largest kit I can go with is the 355MM BBK that fit my track set up. So some diminished braking performance from a standard 380MM BBK kit.
    What would you do?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Apr 04 2012
    MSP
    It all depends on your budget.
    If you can afford a BBK then now is the perfect opportunity as you are forced to spend $ on new brakes. I always say upgrade at these junctures if you can afford to do so. If 355MM BBK is all you can fit then go for it.
    BTW - next time know how much pad you have left before doing a track day LOL.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OP, you have PM. Replacement seals/dust boot kits are dirt cheap if you decide to go that route.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by LINDW4LL View Post
    Thanks, weird that ecs tuning for example has the caliper repair kit at $90 while the link you sent has it at $2.87...lol. I agree the cost for 2 rubber pieces should only be $3 but what a racket!
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    If you decide to upgrade let us know. We recommend StopTech kits from experience. They are designed for each application and keep the brake bias in check.
    Here is a link to one of the many kits and more information about it. http://vag.excelerateperformance.com.../i-225702.aspx
    All StopTech® Trophy Big Brake Kits include:
    • Patented StopTech® AeroRotors® for optimized airflow
    • Patented, billet 7075 aluminum AeroHats® to further increase airflow
    • Forged StopTech® STR calipers with patented bolt-in bridge for ultimate stiffness
    • StopTech® stainless steel brake lines
    • Race engineered caliper brackets
    • Hard-anodized finish on calipers and hats that resists fading and discoloratio
    Oct 13 2009
    MN
    Quote Originally Posted by db12 View Post
    What would you do?
    Go for the BBK. And shop around you'll be surprised at the prices you'll find.
    I've got the Stoptech kit. I haven't upgraded the pads it comes with since I have yet to hit the track but I'm pretty happy with them. Would love to go with the brembos, just too rich for me at the moment.
    Aug 12 2015
    Minneapolis MN
    I went with the Stoptech BBk...decision made. I have heard minor issues with rusting....anyone else have that problem. I live in MN so this winter may be especially brutal on them. Anyway to alleviate that?
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    When you get them installed post some pictures! If we can do anything else for you in the future be sure to let me know.
    Thanks,
    Alex
