Torque Solution Engine & Transmission Mount kit
Applications: Audi A3 ALL & TT MK2 2.0T
Torque Solution engine & transmission mounts are made from high grade 6061 billet aluminum material. The factory mount is a rubber material that cracks and contains a viscous oil and is prone to failure leaving fluid all over the engine bay. Torque Solution mounts come standard w/ Limited Lifetime Warranty polyurethane bushings giving you peace of mind. By tightening up the drive line you are allowing the car to put more power to the ground and into the rotating tires. Our mounts have been tortured tested and proven to last a lifetime. These mounts bring world class performance to you for an affordable cost. Rest assured you are getting a mount that will be reliable for years to come and to help you win on race day!
*Will fit all Audi/VW vehicles with transverse mounted 2.0T FSI and TSI engines.
- Eliminates wheel hop / traction loss
- Improved 60fts / e.t's
- Made out of lightweight 6061-T6 billet aluminum
- Real World Torture Tested
- Black anodized / Torque Solution Laser engraved
- 75A durometer bushings
- Limited Lifetime Warranty
Application List
Audi TTS MK2 2.0T FSI 2009-2015
Audi TT MK2 2.0 TSI 2008-2015
Audi TT MK2 2.0T FSI 2008-2015
Audi A3 8P 2.0 TSI 2005-2013
Audi A3 8P 2.0T FSI 2005-2013
