Results 1 to 16 of 16
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    Angry Help with Cam Position
    OK, need some help here. I am getting cam position codes on my 05 a4 1.8t. I have replaced the cam sensor multiple times, checked and double check the timing (also paid a local VW shop to check it). Timing is spot on. Car runs great and holds boost good, but falls flat on its face between 4-5,500k. Definitely timing related. I have access to VCDS and was wondering if I can log the channel to see if its the ecu that is the fault or something else.
    I have replaced the following trying to figure this out (i have come to the conclusion that it has to be electrical because of the speed in which the problem occurs, it falls on its face for 2 seconds then you get full power again).
    New cams (intake & exhaust)
    New lifters
    new cam chain
    new cam chain tensioner (oem)
    used cam chain tensioner (known good)
    new cam sensor
    new timing belt and tensioner
    new fuel pump
    new injectors
    I have both the stock tune and 1+ tune installed and it does it with both of them.
    Anybody have any advise?
    Thanks
    Jesse
    Established Member Two Rings mdh's Avatar
    Jul 22 2015
    Missouri
    Have you checked your cam chain tensioner sensor? Sounds possible that the motor could be asking for variable timing and isn't getting it due to the chain tensioner not functioning. Just a thought.
    2002 a4 Quattro 1.8t
    APR Catback, GIAC stage 1, ARP head bolts.
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    Yes, I've replaced it 2 times, once new and once with a known good one
    Sep 14 2015
    portage, mi
    how does one get there 1.8 to rev to 500,000 rpms?
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    Quote Originally Posted by storey618 View Post
    That would be sweet. Mistype should have said 5.5k
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    Have cam timing issues too, but probably not the same kind.
    My next step is replacing the Crank Position Sensor or Engine Speed sensor.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Sep 14 2015
    portage, mi
    i was told by a local vag mechanic that he has never had to replace a cam sensor because they just dont normally go bad. when i had a cam code pop up it was a boost leak. how do you know its holding boost, do you have a gauge?
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    Yes have boost gauge
    Oct 29 2005
    10speed
    San Francisco, CA
    sounds like the keyway on either the cam or crank may have sheared but is jammed in place. The marks would lead you to believe that you're spot on but the actual timing is not
    - Clint
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    when the chain tensioner is going out, you'll receive timing errors.
    P1340 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28) Incor. Correlation - 002 Lower Limit Exceeded - Intermittent
    P0012 - Bank 1 Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded) - 001 Upper Limit Exceeded
    These two generally appear together. If they do your chain tensioner is dead, or on its way out. Almost never does the actual camshaft timing sensor go out. If your tensioner is bad you will have a loss of power. Also check your cam timing. If you're off by one tooth you'll have a loss of power. You'll need to remove your upper and middle timing belt cover to see the TDC alignment mark on the lower cover. You will also not see a trouble code for timing off by one tooth.
    we'll need to see any logged faults to determine what is the issue. If it was a boost leak, your ECU may not give you a trouble code. mine didn't, but you'll have a loss of power.
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    I'll go grab codes in a min
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by JHarris View Post
    While you are at it monitor measuring block 90 position three or block 91 position four to read the actual cam position. Take a spin around the block and watch the readings. Under mild acceleration around 2,000 rpm you should see the cam advance go to +22° and around 4,000 rpm it should drop back to 0° advance. I took a spin around the block last week to confirm the readings for Cmiguel32. My readings ranged from -1° retard to +23° advance depending upon engine load and RPM.
    Edit: And most definately take a close look at your keyways as Clint has suggested.
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    https://youtu.be/v2Kq28W6u4w
    Here is video. This is on stock tune. When it's done raining here I'll take it around block and check those blocks
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    P0340 code, didn't get to vcds car tonight as I did not stop raining
    Aug 09 2012
    2005 Audi S4 Cabrio
    Ocala, FL
    Code is 17748
    I check measuring blocks, range from +22 to -1
    Is there anyway to test the speed sensor?
    Aug 26 2005
    The cam position DTC is specifically regarding the timing relationship between the cam position sensor and the crank position sensor. If after changing everything you mentioned, that really only leaves the timing belt drive sprocket position on the crankshaft as the most likely cause of the DTC stored. It does not take much error to set the DTC. The only item left is the crank timing belt drive sprocket position on the crankshaft as Clint and others have suggested.
    Vorsprung durch Technik
