Results 1 to 4 of 4
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Squeak either from car when put into gear
    I am not sure if anyone else has this problem. I get this weird squeak noise when I put the car either in drive or reverse and then begin to move. I hear it more now when I slow down to a roll and then begin to accelerate. It almost sounds like the calipers releasing or something with the tranny. Not sure if anyone has this issue also.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Oct 30 2012
    Arizona
    Have somebody stand at the back of your car and listen for the valves on the exhaust...when putting it into gear, they might squeak since they actuate and are throttle and gear dependent. BTDT...high temp grease or lube.
    Active Member Two Rings Nanofun's Avatar
    Oct 07 2017
    Texas
    Was this ever resolved? My car has developed a similar Squeak. I was thinking exhaust system movement? Something metal to metal that flexes.
    Oct 07 2017
    Texas
    Quote Originally Posted by Nanofun View Post
    Update. Cleared on its own with more use. Just had to put some miles on it
