So I was recently installing a set of JHM intake spacers and ran into some trouble.
For some reason the fuel rail was not coming out without considerable force. Everything was disconnected and should have just come straight out (like the video showed on the instructions DVD). So as it finally came free, it caught on the wiring harness and pulled one of the connectors right off of the harness.
Additionally, I had three out of the 8 o rings come off of the ends of the injectors. FML.
Is the injector harness repairable or does it need to be replaced? I have seen some connectors online but am not sure if it will do the job. As far as the O rings go, I think the O ring is fine. It's the brown plastic ring on the end that has broken.. Do replacement O rings come with that plastic bit?
