Results 1 to 7 of 7
Thread: CEL on P2293
    Aug 21 2016
    96 Honda Integra
    Kennesaw, GA
    CEL on P2293
    So I have a 2006 Audi A4 2.0T Quattro. I'm having a problem with my CEL being on and throwing code P2293. I've changed a few things on it and I can't seem to figure it out. I've searched on here and did what info was provided. I'm out of ideas.
    Low pressure fuel sensor
    Fuel pressure regulator
    HPFP - LPFP
    Fuel filter/pressure regulator
    I am losing problem as well. Once I hit 2700-3000 RPM. The car feels like there is no torque at all. It happens sometimes. After driving the car for a while. Like if I were to start it right back up after driving it. The car will perform well. But give it a few and it starts again.
    Aug 21 2016
    96 Honda Integra
    Kennesaw, GA
    Is there anyone out there that can help me out?
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    Came across this - HTH: https://youtu.be/TDF9PWJq_Aw
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Aug 21 2016
    96 Honda Integra
    Kennesaw, GA
    My car doesn't shut off. I have a check engine line. I've changed a lot of things. Maybe I'm missing something. Thanks though for at lease replying.
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    I just ordered a fuel pressure sensor in hopes it helps me out. I'm having an issue where it cuts off under hard acceleration somewhere between 3-4k rpm. Also noticing a little hard to start when cold.
    Sep 24 2019
    Poconos, PA
    Hey did you figure out / fix the issue? I'm experiencing the same thing, p2293 code, lost of power going uphill, feels like the vehicle has a governor above 3000 rpm & when I get gas the vehicle takes awhile to start back up afterwards.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    fuel pressure / fuel pump?
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
