HI all, I did a auto to manual swap on and used 6 speed manual trans from a 2003 A4 3.0 that was supplied. Going into it I knew that the 2002 needed a speedometer input from the transmission that the 0A3 did not have. I was hoping to use the ABS module from the 2003 but no such luck on the speedometer function. Not only was the 3.0 module bad, no speedometer input....
I don't know if anyone else has overcome with different coding, cluster... etc?
Thanks in advance for the help.
