Results 1 to 10 of 10
    Aug 21 2016
    Virginia
    S6 Trailer Hitch Options
    Hello All,
    New guy here looking for a little clarity on trailer hitch options for an S6. I see the standard curt class I hitch that bolts to the spare tire well. I would prefer something that is hidden when not in use. Any chance that the allroad style hitches will fit?
    Also curious about the wiring. I know ARs offered a factory harness. Is it possible/ worth while adapting this rather than an aftermarket harness?
    Sent from my SM-G900V using Tapatalk
    Veteran Member Three Rings G0to60's Avatar
    Oct 25 2011
    90 Corrado, 02 allroad
    Milwaukie, OR
    I'm pretty sure that the hitch from an allroad would fit the S6 since they are on nearly the same platform. There is a guy who is building a new patch of hitches right now if you want to get an order in. Here's the thread where you can contact him and see some pictures: http://www.audiworld.com/forums/audi.../#post24848944
    As for wiring, I'm not sure. I know that on allroads from 2002-2005 they came with the wiring pre-installed. Early ones were a special order. You may be lucky in that they installed them on all 2002 and later wagons. Take a look under the rear bumper close to the center line of the car. You may see an round connector under there. If you do then you're golden.
    Sep 16 2010
    Central Wash
    The Allroad hitch bolts up to the S6 perfectly, you'll have to trim the valence under the bumper a bit, there's kind of no clean way to do it. You might just want to remove it.
    As for the wiring- I bought an OEM harness and adapted it. DON'T BOTHER! I got it from Europaparts and it was super expensive and a headache to get right. And then I needed an adapter from Euro to US /4pin that I got from the Rover club, also expensive.
    Only nice part was it would tell you if you had a bulb out, which seemed like always. Amazon has a couple choice of wiring kits for about $40 that work great.
    Aug 21 2016
    Virginia
    Quote Originally Posted by G0to60 View Post
    Sweet. Thanks for the info. Looks like that hitch is the way to go.
    Aug 21 2016
    Virginia
    Quote Originally Posted by rollerton View Post
    I figured it would bolt up. I haven't had the opportunity to take a look under an allroad to compare.
    How well does the S6 tow the travel trailer? Is that a Scamp?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by Grnson View Post
    It pulled that trailer like it wasn't even there, no trouble at all. I've since sold the trailer, it was a 'Trillium' ..throwback to the 70's like the early Scamp.
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    I have the curt hitch and it's great for the price. Not hidden, but it's not very noticeable at all when the ball mount isn't installed. Here's my review on amazon: https://www.amazon.com/review/R2PM5VKHXZSYFA/
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    I'm developing an unhealthy compulsion to buy a trailer now.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Senior Member Two Rings Landspd's Avatar
    May 30 2007
    Dallas, TX
    I'd love a hitch, so I can get a small trailer to tow the motorcycle to the track with.
    Sep 16 2010
    Central Wash
    If I can't find a deal on one over the winter I'll probably just weld up my own. The one I used to have was OEM, but it's really quite simple, there wouldn't be anything technical about making it- just need a hardcore welder and some heavy steel. I have an old Milwaukee Arc welder that I've used to make motor mounts/crossbars from scratch.
    It's about $100 in steel. And most of the bends you see in this picture could be avoided. It's just steel that replaces the bumper mounts, and a cross-bar in between, with the vertical part for the receiver, and you can buy that off ebay for like $35.
