So I've finally tracked down where all my rear end vibration is coming from and the 2 mounts (034 sells the carrier mount inserts for) have pulled halfway out of the frame and are completely disconnected from the frame itself (I can see the rubber and that it's been pulled out). I've been searching and searching and everything comes up with the part number for the main mount on the front of the differential but not the 2 rear ones. I'm not sure if they're replaceable or not but I can't find ANYTHING on them anywhere. Maybe someone here has had the same issue?
