Up for sale is a set of B6 S4 Bi-xenon’s that were removed from my 2005 S4. They should fit any B6 bodystyle. These are the self-leveling lights with the mounting tabs intact. One has some internal damage, thus the price. Overall the lenses are in great shape with no cracks or scratches/major rock chips. The right headlight is perfectly usable as is. Perfect if you want to replace some broken parts on your current lights or build your own set with just a few parts (2 ballast caps and an alignment dowel/ball). Both lights do power on and all low/high/turns work. I ran them in my A4 the way that currently are temporarily to get my state inspection (making a custom headlight intake port) and had no problems passing. The lights were never joey modded or had the amber reflectors removed. They are a little dusty from sitting in storage.
$275 shipped to the lower 48. The right assembly alone goes for this much on fleabay. Paypal only.
The right headlight has a Valeo Ballast- VW Part # 3D0907391B(looks original). The ballast holder is cracked in a few places(common issue) but holds to the back of light assembly just fine. It had no leaks whenever I washed my car. The bulb is an OSRAM XENERAC D1S 35W 66043.
The left headlight was dropped while removing it from the car (about 2.5 feet) and one of the balls that reside in the alignment cup broke. (Its the left uppermost piece of the 3). The ballast mounting cap is broken in 3 pieces and is still held together by the screws but I would replace it as it has a small piece missing from the top right corner. The ballast was replaced with a Valeo unit by the P.O. The bulb is an OSRAM XENARC D1S 35W 66043.
Picture of broken alignment dowel/ball
Picture of broken Ballast cap
Left headlight
Right headlight
Both Lights
