Results 1 to 25 of 25
    Jan 15 2014
    Chicago
    Engine Fan Always Running
    I have a 2013 Audi A4 in which the engine fan runs in the following scenarios. I'd like to know how to narrow down the cause of this issue.
    1. Right when I start it and will stay on as long as the engine is running.
    2. The fan will stay on for 1-5 minutes after I turn off the car but I read this is normal.
    3. When I open the door and wait about 10 seconds the fan will turn on for about 5 seconds and then go off.
    I read this could be related to the ECU, thermostat, fan control module, or fan relay. I have a APR Stage2 tune which was flashed through the port so I'm not excluding an ECU issue. Most of the issues I have read are drivers that have their fan on even if the car is off. Like stated above, the fan does turn off after a few minutes when I turn off the car. I have no CEL but my VCDS scan pulled a 0480 fault code - Coolant Fan Control Circuit 1 and a few other unrelated faults.
    Can someone help me troubleshoot this? The VCDS scan is below.
    Thanks,
    Doug
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
    6C 72
    Mileage: 70070km-43539miles
    01-Engine -- Status: Malfunction 1010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CDN.clb
    Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
    Component: 2.0l R4/4V TF H09 0007
    Revision: ECH09---
    Coding: 4A2A0013242600062000
    Shop #: WSC 44403 000 1048576
    ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
    ROD: EV_ECM20TFS0118K5907115F.rod
    VCID: 3561F197945BA1EA43-8060
    1 Fault Found:
    4527 - Coolant Fan Control Circuit 1
    P0480 00 [047] - Electrical Malfunction
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 70040 km
    Date: 2016.08.19
    Time: 11:19:48
    Engine speed: 792.00 /min
    Normed load value: 25.5 %
    Vehicle speed: 0 km/h
    Coolant temperature: 79 °C
    Intake air temperature: 40 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 13.499 V
    Unlearning counter according OBD: 40
    CAN status - engine control module-Bit 0: 0
    CAN status - transmission control module-Bit 0: 0
    CAN status - brake control module 1-Bit 0: 0
    CAN status - brake control module 2-Bit 0: 0
    selected gear-Bit 0: 0
    Readiness: 0010 0101
    Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
    Part No SW: 8K0 927 158 T HW: 0BK 927 156 AL
    Component: 0BK 20TFSIUSA H16 1003
    Revision: --H16---
    Coding: 000002
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMAL551211 002020
    ROD: EV_TCMAL551211_AU48.rod
    VCID: 479D8B5FFEB7237A21-8012
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
    Component: ESP8 quattro H09 0100
    Revision: -------- Serial number: --------------
    Coding: 2D1D18
    Shop #: WSC 02391 823 56573
    VCID: 04075C538701C86284-8050
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 FM HW: 8K0 907 064 FM
    Component: BCM2 2.0 H10 0602
    Revision: 00002001
    Coding: 0D810000000000000000
    Shop #: WSC 02399 823 56573
    VCID: 000F50439319D442A0-8054
    Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
    Component: J764 ELV MLB H40 0046
    Serial number: 2312000071773015
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:44
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8K1 820 043 N HW: 8K1 820 043 N
    Component: KLIMA 3 ZONEN H04 0123
    Revision: C1000000 Serial number: 01130420120539
    Coding: 6480208000
    VCID: 3365CF8F922FBFDA6D-8066
    1 Fault Found:
    01314 - Engine Control Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:43
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 DH HW: 8K0 907 063 AH
    Component: BCM1 1.0 H14 0103
    Revision: 08014001 Serial number: 00000028760601
    Coding: 26000091863CAFC00000480300003D0D0F1C5208A209022100 0008000000030100000030000000
    Shop #: WSC 01837 002 1048576
    VCID: 78FF38A3CBC99C8298-802C
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 170412 H07 0070
    Serial number: SWF12040175110
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 20242771
    Coding: 02005D
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000000304120860
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 0000002274555R1G7G02
    Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: 92780326000000000001
    1 Fault Found:
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:44
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
    Component: AirbagVW-AU10 H45 0610
    Serial number: 003KJD903T5F
    Coding: 303844354730303030304A55304C384B3053
    Shop #: WSC 32235 002 1048576
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 4A9BB26BEDA5DE123E-801E
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R1200008J32
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME6D054A2AN
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME6C646862O
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME5212317A8
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME1D130958I
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME0613184AW
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME71123474T
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
    Component: Lenks.Modul H03 0004
    Revision: -------- Serial number: 90372LDB000GE
    Coding: 000036
    VCID: 43859F4FC28F0F5AFD-8016
    Component: E221 - MFL H03 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 982 A HW: 8K0 920 982 A
    Component: KOMBIINSTR. H35 0540
    Revision: 00000000 Serial number: NTC29934D
    Coding: 8B3709000301D705020000
    VCID: 326BCA8B6D35B6D266-8066
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:44
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
    Component: GW-BEM 4CAN-M H10 0025
    Revision: 1Y030014 Serial number: 1441Y1241500A9
    Coding: 00C303FF00
    VCID: 3F8D93BFAE676BBA99-806A
    Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
    Component: J367-BDMHella H03 8041
    Serial number: 1567047301
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 24
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:44
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 12.40 V
    Count: 6
    Bin. Bits: 10000
    Time: 25.40 s
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0076
    Revision: AA000000 Serial number: 00000027616709
    Coding: 00581B00000000000000
    VCID: 3B75E7AFBA7F779AB5-806E
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 G HW: 8T0 959 793 G
    Component: TSG FA H09 0302
    Coding: 011C13204E00410001
    VCID: 4D91B97714CBC92A1B-8018
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H36 0507
    Revision: 00001000 Serial number: 0030477553
    Coding: 100000000001
    Shop #: WSC 02101 444 125925
    ASAM Dataset: EV_RCEPSAU48X 008014
    ROD: EV_RCEPSAU48X.rod
    VCID: 3467CC939F21B8E274-8060
    1 Fault Found:
    3158274 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:44
    valid
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0174695901
    Coding: 0106063A00FA400580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
    Component: GTO BF H01 0080
    Serial number: 00000000000000512057
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
    Component: J245 PS050 H08 0043
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:44
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
    Component: DSP Prem H04 0030
    Revision: 00004001 Serial number: 94814002588601
    VCID: 2D51D9F7740BE92A3B-8078
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 G HW: 8T0 959 792 G
    Component: TSG BF H09 0302
    VCID: 4C97B473EFD1C0220C-8018
    Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
    Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
    Component: EPB-4 H01 0001
    Revision: -------- Serial number: 30000000039035
    ASAM Dataset: EV_ParkiBrake 001022
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 3663F69B895DAAF24A-8062
    5 Faults Found:
    334080 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:43
    Voltage terminal 30: 12.3 V
    Internal Fault ID: 51
    Network management state: normal
    Function light in parking brake button: OFF
    Red operating lamp: OFF
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: Not operated
    Status ParkingBrake left: Open
    Status ParkingBrake right: Open
    331264 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:43
    Internal Fault ID: 99
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    331520 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:43
    Internal Fault ID: 100
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    331776 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:42
    Internal Fault ID: 101
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    460800 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Date: 2016.08.09
    Time: 11:10:44
    Internal Fault ID: 144
    Yellow warning lamp: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 C HW: 4G0 035 082
    Component: Radio U SIRIU H53 0101
    Revision: AB001007 Serial number: 236D.0C7531693
    Coding: 020007010000000001
    VCID: 204F30C333D9344280-8074
    1 Fault Found:
    03278 - Functionality Limited due to Missing Messages
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:48
    Freeze Frame:
    Bin. Bits: 00000000 00001000
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8R1 035 746 A HW: 8R1 035 746 A
    Component: H-BNT-NA H42 0422
    Revision: -------- Serial number: 096D%0C7506854
    Coding: 0F0200000006E1EF41028F4E00000403140000000000000000
    VCID: 3561F1979C5BA1EA43-8060
    Subsystem 1 - Part No: 8R0 060 884 AD
    Component: NAR 2011 0505
    Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
    Component: DU7 High H41 0104
    Serial number: A130CY0CS133211
    Subsystem 3 - Part No SW: 8T0 919 611 C HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0020
    Serial number: 00000001127334
    Subsystem 4 - Part No: 8R0 060 961 B
    Component: CD-Database 3371
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 24
    Mileage: 70040 km
    Time Indication: 0
    Date: 2016.08.19
    Time: 11:26:27
    Freeze Frame:
    Bin. Bits: 00000001 00000000
    Bin. Bits: 00000000 00000000
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 0
    Mileage: 69773 km
    Time Indication: 0
    Date: 2016.08.09
    Time: 11:10:53
    Freeze Frame:
    Bin. Bits: 00010000 00000000
    Bin. Bits: 00000000 00010000
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 H HW: 8T0 959 795 H
    Component: TSG HL H07 0302
    Coding: 010C13204000210001
    VCID: 50AFA00303F9E4C270-8004
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H07--- Serial number: 525PA8-J23908F
    Coding: 1000006
    Shop #: WSC 02391 785 00200
    VCID: 387FF8A34B495C8258-806C
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H07 0302
    End-------------------------(Elapsed Time: 03:42)--------------------------
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    Jan 15 2014
    Chicago
    Is there any way to verify it is the fan control module before purchasing it? I read a lot of fan control module issues cause the fan to always stay on until it drains your battery. Mine does turn off after the car is off for a few minutes.
    Jan 15 2014
    Chicago
    Update: Would I be correct in saying it's an ECU issue if my egine fan sometimes comes on for a few seconds after I open my door while the car is off? This is in addition to the fan always running while my car is running and running between 1-10 minutes after I turn off my car.
    Jun 26 2009
    Bremerton WA
    In VCDS Module 1 engine go to measuring blocks and select blocks 38 and 39. These are what the ECU is commanding for fan speed. I had my A/C off and fan 1 was only reading 10% and fan 2 zero.
    VMR 710's, APR software, Eurocode HFC
    Jan 15 2014
    Chicago
    Finally had a chance to test. Mine is reading about the same. Fan 1 at 10.20% and fan 2 at zero. Does that verify an issue with the ECU? what do these percentages mean? Both of my fans were running while I was performing the test.
    Jun 26 2009
    Bremerton WA
    It looks as if the ECU is functioning correctly. It is commanding a normal fan setting and the fans are both on so I would think that the fan assembly is bad. The last things I would check would be that the ECU is receiving a coolant temp reading to help rule out a safety override mode. It should one of the other measuring blocks under engine. I would think the fan control (I believe it is part of the fan assembly) is faulty. I would think it could still be a possibility of wiring (In case the fan module doesn't get an ECU command it may turn to full on).
    http://wiki.ross-tech.com/wiki/index...4/P0480/001152
    It mentions an output test, I haven't looked in VCDS for the test to see whats there.
    Jan 15 2014
    Chicago
    All coolant temps respond with values. Looks like it may be the fan control module or the wiring. Thanks for the assistance.
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    If you have the A/C on, the fan should run all the time. Are you running the A/C?
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Jan 15 2014
    Chicago
    No the A/C is not on and both fans run while the engine is running all the time. My understanding is that one fan is to keep the engine cool and the other fan is for the A/C. The fan also kicks on for a few seconds while the car is off and I open the door. For example, if I open my car door to get something after the engine has been off for an hour, the engine fans will turn on for 3-7 seconds dependent on how hot the engine is. Is there a connection between opening the door and the fan control module? I'm wondering if there is some type of short in the wiring to the fan control module.
    Feb 24 2010
    Austin, TX
    I would use vag-com to look at real time coolant temperatures. I had a fan issue in my mk5 GTI where they'd stay on all the time. Ended up being a faulty thermostat. The ECU was seeing unexpected coolant temps and apparently was running the fan constantly as a precautionary safety measure. There is not a specific fault code for a bad thermostat. There's just codes that point to the thermostat being a possibility in some cases. That said, I feel like your fan control module is just as likely the culprit. Thermostat changes are a complete PITA so I'd try to confirm irregular coolant temps before changing. Otherwise I'd prob try changing the FCM first. Good luck!
    Jan 15 2014
    Chicago
    The temp was reading 96 Celsius. I read this is the normal operating temperature.
    Aug 06 2012
    Parker, CO
    Isn't there a sensor on the radiator that reads the coolant temp and it triggers the fans when a certain temp is reached. Check there first
    Aug 06 2012
    Parker, CO
    A quick Google search found the coolant fan switch is likely your culprits ----- and it looks fairly easy to replace
    Jan 15 2014
    Chicago
    Is this the same thing as the fan control module? Seems like two different things. Why do you think it's the fan switch and not the fan control module?
    Jan 15 2014
    Chicago
    Quote Originally Posted by freshwun View Post
    I believe older vehicles use the fan switch and newer vehicles use the fan control module. So we are essentially talking about the same thing. Please correct me if I'm wrong.
    Jan 15 2014
    Chicago
    Would VCDS tell me if the cooling fan switch is bad?
    Jan 15 2014
    Chicago
    Does the coolant fan switch only turn on the engine fan and the 2nd fan gets turned on by the A/C? If so, I would think my issue is still the fan control module since both fans always run at the same time.
    Jan 15 2014
    Chicago
    I replaced the fan control module and the problem still exists. Could it be the ECU? Fan switch? I'm thinking it's the ECU because both engine fans also turn on for a few seconds when I open my car doors while the engine is off.
    Can someone explain in the VCDS what the measuring values mean for the coolant fan? Should coolant fan 1 be 10.20% and coolant fan 2 be 0%? Both fans are continuously running while performing the test. Does zero percent mean the fan should not be running?
    [IMG][/IMG]
    Jan 15 2014
    Chicago
    It turned out to be an ECU issue.
    Nov 23 2009
    NYC, US
    How are you going to fix this ECU issue? Do you need a new ECU or just the programming is messed up?
    Jan 15 2014
    Chicago
    I purchased a used ECU with programming. Everything works except I'm getting a message where the trip meter is saying, "SAFE". I also see a fault in VCDS saying the immobilizer has not adapted. I'm trying to work with the vendor on a resolution. I'm also going to send my original ECU to APR to see if they can fix it in case we can't get the purchased ECU to work correctly.
    Jan 15 2014
    Chicago
    Turned out to be the ECU. Sent it to APR and they fixed it.
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    I'm having the exact same issues. Fans full speed with cold starts, a/c off, then with key ignition off , open door fans kick on. Did some logging, coolant & oil temps are good and get the same Fan 1&2 results as you. I wonder if APR can see/find the ECU coding issue/s or just resets it. I'll make a call to APR in the next few days.
