Results 1 to 7 of 7
    Established Member Two Rings halej's Avatar
    Jun 05 2016
    South Brunswick NJ
    Can my stock brake state handle 475 horse? 2013 Audi s4
    Jun 05 2016
    South Brunswick NJ
    System not state
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    brakes are about endurance and less about stopping power.
    I mean obviously brakes are about stopping power, but really your stock brakes are going to be fine going into turn 1, and 2, and 3, and prolly 4, 5, 6, and 7. but after repeated laps, a stock system vs a larger, better cooled system is going to where you can see the differences.
    Your stock brakes will not feel the same on turn 1 lap 1 as they do on turn 1 lap 5. an upgraded bigger system might feel the same.
    So really its about application, are you ever going to track your car? if not, the stock system is more than ok. Are you going to auto x, stock system is still going to be ok, maybe higher temp pads. if you are going to do multiple track days a month, it's prolly in your best interest to get a better system in place.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Nov 18 2014
    Jersey
    Cliffs on how to get 475hp. kthx
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    At my power level (5xxhp) they are now "adequate" for repeated braking from 120-130mph down to ~20mph... I'm considering the JHM bbk
    Agreed with shickadance, all about what your intended use is... You'll have to elaborate.
    edit adding on. the stickied track drivers thread has a bunch of setups shared. I found the oem brakes fine for daily driving. There is some fade after 6-7 passes at the strip when I'm hot lapping the car or slowing down repeatedly from ~130. I find the rotors a bit undersized too.. I think the JHM kit will provide that extra bit I feel the car could use with slightly larger rotors and a nice caliper
    Quote Originally Posted by Rez90 View Post
    Easy. Dual pulleys. 93/e85 mix and a proper ecu tune.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Quote Originally Posted by mrmomo313 View Post
    Not to hijack the thread. Which pulleys are you using for the dual pulley setup? Currently bought the APR supercharger pulley and the car is getting other work done. Since the front end is off I'm interested which pulley system would work best? Also installing AWE cold front system. I noticed some were using Fluidampr and JHM...thanks in advance
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    yes, your brakes can definitely handle 475hp, as they aren't doing anything during acceleration
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
