i have a 2000 b5 tdi, the front windows haven't worked since i bought the car. after i day of removing window motors, and swapping between doors and switches, i have found that all my window switches work, and all my window motors work, however the front windows in the car will not go up or down, when you push the button, all that happens, is a click from the window motor, that you can hear, and also feel if you touch the motor. you would think that the motor was jammed, but like i say, when i had the same motor plugged into the rear door of the car, it worked perfect.
I'm just wondering has anyone had the same issue or similar, or if anyone could shed some light on what the problem may be, as I'm stumped.
any help would be much appreciated, thanks
