Results 1 to 40 of 58
    Senior Member Two Rings UWbadger91's Avatar
    Apr 03 2016
    Wisconsin
    Adding "Audi Rings" option to 2016 S3
    Hi everyone. My mom just bought a 2017 A4 and it has the Audi Beam Rings option where it shines the Audi rings on the ground when the door is open. I see that the light bulbs are available for the A4 but don't see anything for the S3. Has anyone added these to their S3? Any help would be much appreciated!
    https://www.ecstuning.com/Search/Sit...ght/ES2925542/
    Mar 21 2015
    Apr 03 2016
    Wisconsin
    Thanks for the reply...ECS has them but i don't know if they would be comparable with the S3
    Apr 11 2016
    US
    I have added them to my 2016 S3 - I got them from deutscheautoparts but you can search the P/N and find other places also.
    Mar 15 2016
    I also ordered mine from deutscheautoparts for my 2015 A3. The Oem audi ones from deutscheautoparts was actually my 3rd set I tried and the best ones as they should be.
    The first set I got was a cheap set for aliexpress that showed the rings and the "audi" logo, but it had a purple-ish tint to it. So I then ordered the windfire set from amazon https://www.amazon.com/Wind-Fire-M00.../dp/B00IX5MRD2. I liked this set originally because it uses logo chips that you can replace if you want something other than the rings projected on the ground I liked using the arcade pacman ghost logo with this set. But the downside with this set is that the light beam projector is strong and gets so hot that over a few months the logo faded out on both door sides (which probably explains why audi's oem version has a heatsink on it that your can see from the photos posted above). Windfire offers a free lifetime replacement on new logo chips but I decided to go with the OEM ones and so far I'm the happiest with these ones. The logo is really crisp & bright and looks a lot more premium than the other versions I bought.
    Apr 03 2016
    Wisconsin
    Quote Originally Posted by oblique View Post
    Did you have the lights under your doors already? I just looked and I don't have the lights there from the factory. I'd assume because I don't have the prestige package.
    Mar 21 2015
    Here they are, these should fit multiple vehicles. Looks just like mine
    http://genuineaudiparts.com/parts/in...&siteid=214407
    Mar 15 2016
    Quote Originally Posted by UWbadger91 View Post
    Yes I have the Prestige package on my A3 so it has the puddle lights on all 4 doors.
    I don't know how you would go about installing them if you don't have them though. I remember reading about a guy on the forums
    trying to retrofit them on his A3 but it seemed like more work than it was worth.
    Sep 23 2014
    2019%20S4%20MYTHOS%20LOADED
    MONTVILLE, NJ
    I have a pair from aliexpress if anyone wants them i can ship them
    Nov 13 2009
    the OC, SOCAL
    hows the installation done? is the wiring already there? do we need to pop off the door panel?
    Aug 06 2012
    san diego
    Quote Originally Posted by 949 View Post
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Quote Originally Posted by markn1689 View Post
    If your car doesn't have the LED package either with the convenience package on the 15's or the LED headlights on the 16's then the door does not have these lights. On my 2016 S3 I don't have the LED headlights and the door panel is sealed where this opening would normally be.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Sep 23 2014
    MONTVILLE, NJ
    pm me, ill send you a brand new set for 20$ plus shipping
    Nov 13 2009
    the OC, SOCAL
    so if there are no lights then there are no wires there. how are you guys wiring it up then? unless they are there but just sealed up.
    Mar 21 2015
    Pop it off and look for the wires.
    Jul 31 2008
    17 S3 Nano Gray
    NC
    Anyone with a '17 premium plus pull their door panels off and see if there is any wiring differences? I'm wanting to retrofit puddle lights and footwell lights in my non prestige 17 s3.
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    Quote Originally Posted by tsunamis4 View Post
    If the 17 is the same as 15/16 and I suspect it is. You are going to need the puddle lights, connector, and pins to build the wiring harness. You have to cut door panel to fit the light. Once the light and wiring are installed you will have to code the door modules for puddle lights. I haven't checked for the foot wells but I expect you will have to wire them as well.
    Nov 13 2009
    the OC, SOCAL
    part#: 4G0052133A
    so did anyone find a cheap place to buy the original part from?
    will the rear doors also fit the same part or are they going to need a different part number?
    Apr 03 2016
    Wisconsin
    As far as I know you can't get them anymore. They're on nationwide back order due to Audi pulling them off the market. That is of course if you want the OEM ones. I'm sure yo can get some crap lights on eBay.
    Jul 31 2008
    17 S3 Nano Gray
    NC
    Just ringed version or all puddle light oem variations?
    Nov 13 2009
    the OC, SOCAL
    why are they taking them off the market?
    Apr 03 2016
    Wisconsin
    The ringed version. I had them ordered back in august and I was informed that Audi pulled them off the market. Not sure why.
    Nov 13 2009
    the OC, SOCAL
    what other versions are there?
    part numbers to those?
    Jul 31 2008
    17 S3 Nano Gray
    NC
    Don't know part #s but I've seen pics of the S3 logo and "Quattro". Imagine there are others too.
    Nov 13 2009
    the OC, SOCAL
    i might go for the Quattro version if these audi rings become too stupid to aquire.
    Jul 31 2008
    17 S3 Nano Gray
    NC
    A quick search on eBay will return a number of sellers. Anywhere from 130ish to 200 including shipping.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    These fit b8.5 s4?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Nov 13 2009
    the OC, SOCAL
    saw those, but $130+ish doesn't seem worth it for a different pattern. I am seeing the "Quattro" pattern go for around $90ish. that means I can get a set for the front and rear doors for less than $200ish
    Junior Member Two Rings The_Kracken's Avatar
    Sep 29 2016
    2015 S3; 2012 Q5 ; 1997 Chevy Tahoe
    San Jose, CA
    I bought S3 projector door courtesy lights on eBay. 12.95$ for 2. First set, awesome. Angle and clarity of projected image (S3 logo) are spot on. Bought a second set from same seller for rear doors. Clarity is great buy angles are off. But at $13 a pair i am ok trying a few to get it right.
    Only 3 months having them installed, so can't comment on long term results.
    Sent from my XT1096 using Audizine mobile app
    Aug 06 2012
    san diego
    https://www.aliexpress.com/item/2-x-...08.4.22.eQFUWe
    found these
    only 7.00 for the pair. gotta admit im skeptical tho
    Aug 19 2016
    Southern, NH
    An illuminated red with white S3 badge would be nice. Since us 2015 and 2016 S3 guys don't get illuminated door runner badges.
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    UWbadger91 is correct. These OEM lights are presently not available from Audi.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Sep 29 2016
    San Jose, CA
    Quote Originally Posted by Wr3ks_S3 View Post
    Here's an image of Ebay sourced S3 logo. It's projecting on a gravel road so doesn't look all that great, much better on smooth surfaces.
    https://www.dropbox.com/s/fku1dl262u...12044.jpg?dl=0
    Established Member Two Rings atenzany62's Avatar
    Jan 30 2016
    nyc
    Quote Originally Posted by The_Kracken View Post
    they are the ones being shipped from china? how long did it take to arrive?
    2016 Audi S3 - Glacier White - CF front lip/CF trunk spoiler/19x8.5 Doss FF1/Roc Euro intake/JB1
    Sep 29 2016
    San Jose, CA
    Yes from China and took about 2 weeks to arrive.
    Nov 13 2009
    the OC, SOCAL
    what key words are you guys using for searching on ebay?
    Jul 31 2008
    17 S3 Nano Gray
    NC
    Audi s3 puddle lights
    Senior Member Two Rings 16s3pang's Avatar
    May 07 2016
    07 Mazda MX-5 PRHT
    Goffstown, NH
    Quote Originally Posted by Cairo94507 View Post
    Purchased an OEM set from an Audi dealer in the UK via eBay. Perfect fit finish and the Audi logo is crisp and sharp. Note: these light have the little heat sync build in to the housing.
    |2016 RS7|
    |Sepang|Dynamic Pkg|B&O|Comfort Seats|Aluminum Atlas Inlays|Cold Weather Pkg|Milltek non-res exhaust|Roc-Euro intake|034 Motorsport Drivetrain Inserts|
    Sep 29 2016
    San Jose, CA
    Audi door courtesy projector
    other keywords:
    projector
    courtesy door light
    ghost shadow
    audi
    Aug 19 2016
    Southern, NH
    I know the ebay photos aren't the best quality but the S3 ones seem to blur on the edges. Maybe it's just the pictures....
