Originally Posted by
86turbodsl
Point taken. I'll get a plastic one coming as soon as i can. Any tips on changing it? Or just like it looks, remove intake, and as much of the rear hardware as required to get to the flange fasteners?
Sent from my SM-N910T using Tapatalk
I believe its as simple as removing the intake (watch out for the plastic dowels that ALWAYS break when you remove the intake) and then getting at all the fasteners and clamps. TBH, I would suggest doing 2 other jobs while doing all of this.
#1 Vacuum Lines. Replace them all with silicone tubing. Theres a DIY on here by SlickFix which is the best guide to use.
#2 Replace ALL PCV lines with 3/4" heater hose. If your lines are original, they WILL break when you touch them. Using a combination of heater hose and brass elbows, you can easily make a new PCV system for <$30 compared to over $150 for more brittle plastic lines.
Other than that, you should be good to go for a while after changing all of this out.
