Results 1 to 3 of 3
Thread: Alcantara heat?
    Active Member One Ring Tyygieggs's Avatar
    Jun 22 2015
    Secaucus New Jersey
    Alcantara heat?
    Ok guys I just bought a full set of the grey and black leather alcantara seats my original alacantaras were ripped an destroyed, these ones are almost perfect, I'm a little confused about one thing though mine had a extra plug in for the heated seats these one I have don't have that im just wondering if the heating element is still inside the none heated ones and if I could swap my wirering from my original seats into the new one and it work, searched for a while can't really find the answer I would assume they don't have the heating element inside but it's worth a shot
    Senior Member Three Rings JJ.'s Avatar
    May 22 2012
    Netherlands
    No the heating element wont be present in non heated seats
    -Cactus green Audi S4 B5 on air
    • Instagram: jj_dw
    • Instagram: jjwphotoworks
    Instagram: jj_dw
    Aug 06 2008
    Canadia
    Sounds like you got some non heated seats... The heating element is glued onto the seats and, although possible, would be very difficult to swap over. Your best bet is to buy a couple heated passenger seats (less wear and tear) and swap over the cusions (the part under the upholstery) to give you heated seats, and even that is not exactly an easy task.
    the B5 S4 is like the mafia... there is only one way out!
