    Active Member One Ring trdtyler5591's Avatar
    Aug 21 2016
    Utah
    Pulling codes, need help!!!
    Hello people, I am new to the forum, just picked up a B6 A4 1.8T Avant, automatic. I'm pretty sure this has been mentioned before, but i couldn't find anything. So I'm either blind or retarded lol.
    Anyways, I'm pulling a P0411 and a P0811. The P0411 I imagine it's the Combi valve, but haven't had a chance to look yet. My main concern is the P0811 code. It's stating "excessive clutch slippage", and it's an auto. It has a bad steering rack I'm planning on replacing it, but what's strange is it will drive perfectly fine through all gears, but sometimes (especially when making a left turn), it will be very hesitant (high rpm's before jumping into gear), or wanna start in 3rd gear. "PNDM" are all lit up as well, on gauge cluster.
    Anyone else have similar problems? Or can help and post a thread link to where this has already been discussed?
    Thanks in advance!
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I haven't seen anyone post about that code before, but do you know the last time the fluid and filter were changed in the transmission? That may be a relatively quick option to try and alleviate some of the issues you're seeing.
    Sent from my Nexus 6
    Aug 21 2016
    Utah
    Was planning that, this weekend. I'm new to Audi's. Does a filter/fluid change make a pretty big difference? I mean, obviously if it's never been changed it would. It's sitting at just over 174k miles right now
    Daily: 02' Audi A4 Avant, stock for now
    Wheeler: 96' Jeep ZJ with 3" lift
    Toy: 97' Toyota Soarer with single turbo swap 650hp. Giggity!
    Active Member Two Rings nicktheblasian's Avatar
    Jan 01 2015
    Peekskill, New York
    Quote Originally Posted by trdtyler5591 View Post
    Thanks in advance!
    Did you ever solve this problem? i am currently have the exact same issues youre describing
    turbocharge all the things
    May 16 2017
    Compton
    For the fault P0411 it is secondary Air injection Incorrect flow.
    That means you have to check many components of the air injection that might be leaking somewhere.
    As for the transmission fault whenever the light are illuminated that means something is going on with your transmission control module no communication and will need to be rebuilt electrically
