Results 1 to 10 of 10
    Established Member Two Rings Andrewiffic's Avatar
    Nov 25 2015
    AB, Canada
    B7 A4 only boosting to 7psi
    I have a 2008 2.0T A4. Unitronic Stage 1+ chip. 034 Motorsports HFC. I installed the HFC a few weeks ago. It was running great except I noticed a slight loss of power at low rpms when the engine was cold. After it warmed up it was fine and boosted strong. I got a CEL for the secondary cat a couple times, and reset it. I am planning on going in to get it chipped to Stage 2 which will remove the CEL.
    Anyway, a week ago I noticed power was way down. I checked the boost with the Torque app (I have a boost gauge on order) and it is now only boosting to 7psi max. After searching on here I read a couple possibilities and tried resetting the ECU by detaching the battery for 1 hour last night, but still no change. Does this sound like a blown Diverter Valve possbily? I have a 2008 so I thought I should have the newest DV that is less prone to failure, but maybe I'm wrong? Any other ideas?
    Is this somehow related to the HFC I installed? Because it was running fine and strong before I installed it. And only for a couple weeks after I installed it.
    I VAG-Com'd it and there are no codes.
    B7 S4 6MT | JHM Tune
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I could've sworn no b7 came with the newer style dv and they were all diaphragm but I could be wrong, I'd start there personally if you've never done it
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Nov 25 2015
    AB, Canada
    Quote Originally Posted by pezgoon View Post
    Oh good to know. I was trying to find that info and wasn't sure. So the newest revision valve is 06H-145-710-D right? I'll see if I can find out what I have on mine right now.
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    id get an upgraded dv....gfb or something like that is what a couple of my friends are running...either way that's where id start
    2008 Ibis RS4....GETing tuned
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by Andrewiffic View Post
    you can take it apart first to inspect. But stage 1+, take no chances, order the revision or the GFB DV+. Take the cheapest. GFB would be a better choice imho.
    Worst case, you have a problem with the waste gate, there's a how to how to re-prime it. But the chances are really low that is the problem.
    It can be a valve N?? (can't recall) , but again low chances.
    Start with the diverter valve. It can only do good on your car.
    3 screws, I will take around 1hr to change if you're slow. Do it from under the car.
    Nov 25 2015
    AB, Canada
    Found my problem:
    Just ordered a new 710D revision DV. Hopefully will be here soon. Found the best price from GermanParts.ca.
    Jul 01 2015
    Mtl
    Found my problem:
    indeed , they got good prices and fast shipping.
    Jul 25 2016
    new hampshire
    Yep had a feeling, overdose you were thinking of the N75 valve, which I could've sworn is what the wastegate itself is called? I'm probably wrong though. But apparently right about that DV! Sorry I didn't see your question sooner, glad you pulled it out, your symptoms were yelling either DV or wastegate but I know the DV's are guaranteed to fail with any tune
    Eric
    Active Member Two Rings kNightsfallen's Avatar
    Aug 08 2016
    Fairfield, CT
    I'd be careful... Those turbos don't last much longer than 100k. Not sure what your mileage is... Due to no coolant circulation via after run pump.... Because there is no after run pump. So over boosting them only makes them run hotter and decreases the life expectancy. I just replaced my wife's on her 2008 and she has 115k. And I've replaced more than I can remember for other people.
    Sent from my iPad using Audizine mobile app
    Audi Master Technician
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by kNightsfallen View Post
    Not going to argue that the K03 hasn't failed, but there are things you can do to help keep the turbo running well for the long run. Number one on the list is to not beaton the car and then just turn it off. You should always give the motor and turbo a proper cool down after beating on it by gentle driving for the final 5-10 minutes before shutting off.
    Additionally, if you are tuned,consider shorter OCI (5-7.5k) and be proactive with all recommended maintanence.
    My car has been amazingly reliable. Only issue has been a PCV failure after getting tuned.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
