Results 1 to 4 of 4
    Aug 20 2016
    2009 chevy 3500 4x4 dually, 96 ford ranger 2.3 2wd, zx10r, f250 6.9l 4x4 off road truck
    Gardnerville Nevada
    Audi 2.7t Tiptronic 3" xs power downpipes installation 2004 A6 BEL
    These are some pics and tips for the 3" xs power ss downpipes meant for the tiptronic ZF5hp-19 transmission. I will do an entire Engine /trans removal-Replacement in another thread.
    The downpipes designated for the tiptronic trans definitely need modification. I do not know if they are just the same pipes for the manual with a different label on E-bay. [IMG]aug2016iphone 325[/IMG]
    The pipes are of a quality build, just not a perfect fit since you will need to make multiple dents in them to clear the trans. Plus you will need to remove heat shields and remove heat shield tabs from the transmission to fit them. I cannot recommend heat wrapping them enough! You MUST do this to keep from baking your trans/stuff- but that part is easy and not really expensive.
    [IMG]aug2016iphone 389[/IMG]
    I do not know if this can be accomplished with the engine and trans in the car- if it is possible, I would still not like to try- Perhaps just removing the sway bar, engine cradle and lowering the whole assembly would make it easier but it would be very painful and I would not recommend unless you are a monk, an audi tech and stoned.
    [IMG]aug2016iphone 406[/IMG]
    The downpipe on the passenger side(usa) needs the denting and a different hangar from the bottom of the trans.
    [IMG]aug2016iphone 393[/IMG]
    Here is a photo of the dents you will probably need to make.
    [IMG]aug2016iphone 391[/IMG]
    Here is the heat wrapped downpipes attached to the engine /trans.
    [IMG]aug2016iphone 394[/IMG]
    I wrapped the downpipes with about 30' of 2" heatwrap from O'rielly's . I used galvanized electric fence wire to tie it off in multiple locations along the pipes to avoid any issues- I would recommend stainless wire, but I have checked the wire after running it hard and see no loss of galvanization and do not believe it will be too hot for the wire. Here is the view from the bottom of the v-band clamps prior to the test pipes.
    [IMG]aug2016iphone 407[/IMG]
    The 3" pipes neck down to 2 1/16" ID and slip right over the stock exhaust. Do not try to use the stock slip clamp connector or you will fight it and never succeed.. you can use 2 1/8" exhaust clamps over the connection, and honestly I've been running without any clamp at all , just a slip fit as I have not decided whether or not to do the rest of the exhaust. Hope this helps. I will add more pics and tips after I know this post will work since this is my first time on the forum. Happy Tuning
    Veteran Member Three Rings JTown77's Avatar
    Feb 01 2010
    2002 S6 red, 2003 2.7 allroad stage II blue, 2005 4.2 allroad silver, 2003 FLHRCI
    Charlotte N.C.
    I tried two sets of their dp's neither came anywhere close to fitting. They also tend to black list your number if you call with questions or complaints.
    I have a rosstech vcds HEX-USB+CAN Interface and cam lock bar to rent with deposit in the Charlotte area. Like all C5 owners I am looking for local parts!
    Dec 01 2012
    Charlotte, NC
    I also had these installed on my 04 BEL tiptronic, last summer. Mine required extensive modifications as well to get them to fit.
    Here's a few pics. Areas circled in red are spots where we had to dent / grind extensively to get them to fit.
    Feb 01 2010
    Charlotte N.C.
    Those look a lot closer than the fitment on my 03 BEL Tip.
