Hello, I have a very odd brake drag problem, I'll try to explain as clearly as possible.
Car: Audi A4 B6 2002 AKE 2.5TDI Q automatic.
Problem: FL and RR wheels get noticeably hotter after 60+ km drive, if driven longer it gets so hot the brake pads start to smoke.
How I noticed it: I got the car ~4 months ago, it had new pads, ~4 weeks ago I got pad wear warning on the dash, when I replaced the pads, FL pads were worn to the metal, FR were like new.
Replaced/visited: all brake pads and disks, brake hoses, ABS block (used, same PN), brake fluid, rebuilt FL & RR callipers, lubricated all calliper slider pins with proper lubricant.
Notes to possible problem: The old and the replacement ABS block makes a double click solenoid-like sound on ignition. If I press the brakes before turning ignition on first click is barely heard and second click occurs on brake pedal release (with ignition/engine on). No fault codes. Car is pulling to the right (new tyres, alignment done). Apart from the problem braking feels fine.
Anybody have a clue on why this is happening?.. I think I bought the car with this problem. Can it be some air trapped in ABS block or something? I replaced and bled the brake fluid w/o a pressure bleeder. Can it possibly be something not even associated with brake system like dry CV joint or something?..
