Results 1 to 16 of 16
    Jul 22 2016
    Rumble / vibration when making hard turns from a standstill
    I tried to search for this exact issue but I got other vibration issues that are unrelated.
    In my 2014 B8.5, when moving forward from a standstill and giving only a little gas and making either a hard or right turn (wheel 75% or more to bump stop), when I give it gas I get a rumble vibration throughout the whole car. It's not there when coasting, but as soon as throttle is applied it rumbles. My friend says his B8.5 does the same thing. EDIT: as soon as the car starts coming out of the turn, the rumbling goes away.
    Is it some kind of non slip of the differential in a Torsen setup? Is it tire chatter with quattro? Just caught me off guard and I'm not sure if something is actually wrong or not.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Its normal ... its the Quattro
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    quattro crawl. normal
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Normal takes a while to get used to it.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    It annoys me too. Feels like the car is dragging the tires. But it's normal
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Jul 22 2016
    Awesome thanks, I'm glad it is normal. I'm coming from xDrive and never felt that before, wanted to make sure I wasn't going crazy :)
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    What you are feeling is the friction of the tires scrubbing against the road surface. Since the turning radius of the outside wheels and inside wheels are different, it is difficult for the Quattro system to compensate at very low speeds. So the tires scrub the road surface to allow the wheels to turn.
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by fordperf View Post
    i had the same problem. I was used to my xdrive being very smooth all the time. You get used to it after awhile, although sometimes it still catches me off guard
    www.epautohaus.com for all your aftermarket performance parts, wheels & tires
    Jul 22 2016
    Interesting that someone else is claming (http://www.audizine.com/forum/showth...-B8-5-A4-vs-S4) that the B8.5 has a different center differential and should NOT have this behavior. Yet everyone else seems to be saying it's normal.
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    Its normal.
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    my b8.5 s4 has the quattro crawl
    that guys smokin something
    Jul 22 2016
    A distinct possibility lol
    Senior Member Two Rings osspasha's Avatar
    Sep 18 2013
    I used to have this issue, until i got my timing chain tensioners replaced under the TSB 2039995, and now this vibration is long gone, not sure how it relates, thoughts?
    2013 S4 B8.5
    Don't let fear and common sense stop you
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by osspasha View Post
    Wouldn't seem to have any correlation
    Senior Member Three Rings DufraineMK6's Avatar
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    When I first got mine I thought the tires were rubbing, dealer said the noise was common on B8 S4.
    14 S4 6MT - Sport Diff / H&R Street Performance Coilovers / CW Pro Stage 2 (6-1) 93/E85 Mix / JHM 179mm Crank Pulley (1300mm 7 Rib Belt) / ECS Tuning Flush Kit 10mm F & 12.5mm R / 034 Motorsports Intake Tube W/ AFE Pro Dry Filter / USP Stainless Steel Clutch Line / AWE Touring 102mm Stock Downpipes / Eurocode Trans Mount
    Senior Member Two Rings darkrock's Avatar
    Sep 15 2010
    2013 F150, 2022 Explorer Timberline
    Bergen County, NJ
    Had that same vibration on my b6 from brand new till I sold it at 86,000 miles. Dealer said it was normal
    Sent from my SM-G950U using Tapatalk
    2015 S4 6MT Premium+
    Sport Diff, Brilliant Black, Alcantara, Carbon Atlas, B&O, Tech pkg
    H&R OE Sports, ECS intake, ECS x-pipe, ECS flush kit, Magnaflow 11385, Carbon Imports Low Kick, 3M 20% tint
    Previous:
    B5 S4 6MT AWE Stage 3
    B6 S4 6MT stock
