Results 1 to 8 of 8
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    without having someone look at it
    What are the reasons my car would stop blowing hot air? I want to see if it's something I can fix. I took it to a shop and they misdiagnosed the hell out of this car.
    Jul 04 2012
    Woodbridge, VA
    Thermostat or heatercore is stopped up
    Aug 17 2015
    Holland
    Is'nt the S4 B5 2.7T directly attached to the heater core? Or is that the RS4 B5 Avant only? The RS4 has a permanent 'line' towards the heater core, bypassing the thermostat.
    If that is not the case on the S4 B5, then the thermostat is stuck, not opening, and needs replacement.
    2001, RS4 B5.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by derek2079 View Post
    Either the heater core itself is plugged up (somewhat common), the thermostat is OPEN always, or your water pump has failed.
    You didn't give anywhere near the amount of information needed to diag so, that's what you get.
    Aug 02 2004
    UT
    I do have a bad heater core. I am learning something new everyday.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Aug 24 2014
    Newport Beach, CA
    Lol Zba.
    2024 M3 Comp xDrive
    Aug 02 2004
    UT
    Can we just end this negatively? I was really just excited to be back after years of being away.
