Results 1 to 7 of 7
    Aug 20 2016
    Atlanta
    Pinout for green b1s2 o2 sensor?
    Does anyone have a pick it know the pinout wire colors for the green connector that runs the the passenger side post cat o2?
    - - - Updated - - -
    A pic*
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by Weatherman View Post
    - - - Updated - - -
    A pic*
    On the O2 sensor side of the connector:
    Pin 1: White
    Pin 2: White
    Pin 3: Grey
    Pin 4: Black w/ white tracer
    On the ECM harness side of the connector:
    Pin 1: Green w/ yellow tracer (thicker wire than other 3)
    Pin 2: Yellow w/ red tracer
    Pin 3: Grey
    Pin 4: Blue
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    here is a pic of the O2 plug end if you still need it
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Aug 20 2016
    Atlanta
    Thank you for the help!
    I could use a pic of the harness/ecu side. Trying to replace the o2 and didn't take a pic before I defined the factory plug. It's my fault..
    Thanks again!
    - - - Updated - - -
    Quote Originally Posted by 924Carrera View Post
    Pin 1: White
    Pin 2: White
    Pin 3: Grey
    Pin 3: Grey
    Pin 4: Blue
    Thank you!
    Aug 20 2016
    Atlanta
    Sure enough, I have the heater element and the sensor sides flipped.
    Now to figure out how to de pin this new connector without breaking it like the factory connector...
    May 18 2012
    2005 S4
    Portland, OR
    You probably don't want to wait this long, but there are terminal release tools specific to VW/Audi that work exceptionally well. Assuming you have something sort of like that (a two-prong tuning fork shaped pick), I've found that it is crucial to grasp the wire at the base of the connector with needle-nose and push it toward the connector, to release pressure on the terminal. Then, you can insert the tool which presses down the terminal latches, allowing the wire to slide out freely. All of this of course assumes you have removed the pink terminal lock piece first.
    This is the kit I have: https://www.amazon.com/STEELMAN-9592...terminal+tools
    It's pricey, but has proven invaluable for harness repair.
    Aug 20 2016
    Atlanta
    I sat down and made one from a strong set of tweezers and a file. Worked very well!
    Thanks for your help! Realy appreciate it!
