Results 1 to 14 of 14
    Dec 26 2014
    2017 Audi R8 V10+, F82 BMW M4, 2013 Range Rover Sport
    Hutchinson Island, Florida
    Exclamation Need more rear camber
    Hello, I have a B8.5 RS5 on air suspension. I need more rear camber than factory permits. Does anyone have a solution for this? I've searched quite a bit and can only find front upper control arms! Need to know ASAP thanks in advance
    I'm like 8mm away from tucking my new wheels so I need like 2 more degrees to clear it, any help would be appreciated! So dumb how little adjustment comes from factory!!!!!
    2015 Mythos Black RS5
    HP Drivetech & Accuair Suspension - Accuair E Level Management - Rotiform Wheels
    Sponsored by Rotiform, Toyo Tires, and HP Drivetech
    Veteran Member Three Rings Jester2893's Avatar
    May 29 2012
    Quote Originally Posted by ShaneKucyk View Post
    When I tried searching for a solution to my A5 there wasn't much information available. The conclusion I came to was that the "eccentric" bolt or whatever it is that you use to adjust camber needs to be modified, but could not find any information on modifying it for our chassis. The only info I came across was modifying it for a mk5 VW.
    Dec 26 2014
    Quote Originally Posted by Jester2893 View Post
    Yes, it is an eccentric bolt! Yep can't find anything on it as well, would like to know if its too sketchy to modify the factory bolt.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Im almost certain Audi didn't have a modified car on air suspension in mind when they engineered the adjustment of the suspension
    How much camber do you have at the rear? At 3" lower you should have around 2.5' of negative camber just through the action of the arms, you should still have another 1 degree of adjustment on top of that. Do you need more than 3.5' of negative camber? What size and offset wheels are you running?
    You could try removing the offset washer altogether and seeing if there's any more movement available on the bolt, it there is then you could machine down the narrowest side of the offset washer to give you maximum movement.
    May 29 2012
    Quote Originally Posted by JamesRS5 View Post
    This is what I saw someone do on VWvortex , but this was of course with the mk5/Mk6 chassis. There was also a person making custom aftermarket bolts for more cambers. I would try this first, might bring it in another degree or so. Last resort might have to put a slight pull on the fenders ?
    PS: he needs maximum x maximum camber because he is a dapper stance god and Instagram famous.
    Dec 26 2014
    10.5 +18 with 275/30/20 Toyo Proxes. Sits right on the lip, trying to squeeze it inside of the arch. I've already maxed it out myself. I'll try removing the washer tonight!
    Dec 26 2014
    LMAO! I would have a hard time describing myself like you just did. Just another guy trying to do some stupid stuff to his Audi.
    May 29 2012
    Haha I kid kid, car is gonna look great on those wheels, I just peeped the gram, I guess I missed when you posted them!
    Good luck man sorry I can't be any more help .
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    Have you already rolled and pulled your fenders?
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Reviving an old thread. Did you figure out a solution for this. I need some more camber to tuck my wheels 20x10.5 et22 275/30/20
    Veteran Member Three Rings HMS's Avatar
    Apr 28 2015
    BOS
    No you don't. End thread/
    2013 Audi [R]S5 Panther Black - Mods: 034, Capristo, ECS, H&R.
    Instagram: RS5_onthe_Run
    Jun 29 2019
    Sacramento
    Any update on how you were able to get more camber in the rear? I’m currently at -3.2 an looking to get another degree or 2. Let me know what u found out thank you
    Apr 11 2020
    Tampa
    Any update or progress on getting more camber?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
