Originally Posted by
5ktq
Yeah. There's a green one at the back of the engine (4 pin). That one is for ECU and the instrument panel, afaik.
There's a 2 pin one on the lower rad hose , on the quick coupler, that one must be for fans.
You are mostly correct, the lower rad hose sensor output is used by the ECU to run the driver's side rad cooling fan when the coolant leaving the radiator is to hot, needing more cooling fan air flow to cool the coolant more. The ECU sends a PWM voltage to the fan control module to command the fan ON, and vary the fan speed as needed according to the coolant temp sensed by the sensor in the lower rad hose. The rad fan can run under variable speed depending on engine load and ambient air temps, or for lower load and engine speed regular driving, slow speed of the fan will cool the coolant enough for the ECU to turn the rad fan OFF after the coolant is below the fan ON temp.
The AC condenser cooling fan is the smaller fan on the passenger side, and runs slow when the AC is in AUTO or Manual mode. The AC fan does not run with the AC in ECON mode. The AC condenser cooling fan is controlled by the HVAC controller in the dash.
The fan control module has two separate fan speed control modules inside, one for the the rad fan, the other for the condenser fan. The two fan speed controllers are independent of each other, contained in the same housing and share some electronics, but command and control is separate for the two fans.
