Results 1 to 37 of 37
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Meth for Cooling
    Based on the threads I have read and some initial logs from a local buddy (using the AEM Meth setup with a 500cc Nozzel right after the filter element on his ROC Euro) it seems a 50/50 Meth/H2O mix adds octane (seeing 1.5psi extra) but does very little for IATs.
    Would a 40/60 Meth/H2O mix help IATs more? Or maybe its dependant on Nozzle location?
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by GRUMPY-S4 View Post
    I think the 1.5 extra PSI is coming from cooler (more dense) air. With that, extra boost creates more heat once it goes through the S/C, so some of the cooling effects are negated in terms of IAT's.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Nov 16 2015
    DFW
    Quote Originally Posted by jran76 View Post
    Thats what Tom and I were discussing. So the IAT is measured post charger?
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Correct, its post charger. Meth would benefit for extra fueling though...
    Our set-up isn't ideal, post charger doesn't give an appropriate amount of time for atomization, pre charger ends up getting re-heated through the S/C rotors. I'm not sure how others are set up, they may be setting good iat control.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Nov 16 2015
    DFW
    So maybe with meth I can continue to run E85 with the 179 crank pulley and CTS SC pulley.
    Aug 09 2015
    Sarasota, FL
    I think you can run it now, others have. Did you get your EPC/CEL cured yet?
    Nov 16 2015
    DFW
    Quote Originally Posted by Loe View Post
    Yea... Cured with latest file. AndThen is going with a bigger pulley and I am taking his JHM 179. Now with Meth he has been able to run E82 without any bypass. Without the meth he would bypass. He normally had to run E70 or lower.
    Aug 09 2015
    Sarasota, FL
    Depending on your lambda values, you will probably be fine on the 179mm without meth. If you do run into issues, then you may need to blend down to the e70 range, which in my past experience is easier than dealing with whether not the meth pump triggers, and if there is sufficient flow for proper AFR at WOT, and air in the lines.
    Nov 16 2015
    DFW
    Is Tom still working on your car? Tell him to tell u about my Golf R fiasco build that he had to fix!
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    The problem here is the amount of time you have to cool the air. Meth is more effective or can be, on a turbo car. The turbo compresses the air, then there are usually several feet of pipe, combined with an air to air intercooler. You can inject meth pre-intercooler to get the biggest drop in IATs. With our engine, the meth didn't have time to cool anything much, as it's intgested into the engine almost immediately.
    2021 Audi S4, P34 Intake
    Aug 09 2015
    Sarasota, FL
    ...with that being said, its terrible that we are so limited in cooling. The 179mm is so much controllable and consistent with IAT's than higher ratios. Good luck to you both!
    Dec 03 2008
    2018 SQ5
    I'm not saying don't do it though lol. It's still got plenty of advantages!
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    E70 seemed to be the point where andthen ran out of steam in the past....
    Aug 09 2015
    Sarasota, FL
    Not lately, he only installed my coldfront, awe pulley, and jhm crank pulley, pretty "basic" hardware stuff so far. He doesn't do much from the tuning side that's available for our platform, aside from Malone tuning for B8 only guys. Everything else has been Evan@CrownMotorsports or Justin@UroTuning with my doing my own logging/testing what was installed, what happened to your Golf R?
    Aug 09 2015
    Sarasota, FL
    Was E70 the max or min threshold?
    Either way, if Grumpy triggers a lean code on e82-e83, he may need to blend to reduce the ethanol if he's at the limit. He may or may not be, only way to find out to to try it and log.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    At e82 was he bypassing because of heat or because he was starting to lean out?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Nov 16 2015
    DFW
    Quote Originally Posted by Hofahome View Post
    Because of Injector Pulse Width. Never a pressure issue. He was just not able to get enough fuel in the cylinder above E70.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    http://www.audizine.com/forum/showth...=1#post4877386 may be of interest to you.
    Furthermore, we have found that different compressors require more or less jetting. For example, twins screws and roots style superchargers with the water injection placed before the compressor require nearly one and a half times the jetting as do centrifugals and turbochargers at the same horsepower and boost levels. This is largely due to the injection being sprayed through the unit, the vast surface area of the rotors and due to the added heat they create vs. centrifugals and turbochargers."
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Aug 09 2015
    Sarasota, FL
    On the 179mm?
    glad to see that he's out to see if the S/C will hold up to 26,000rpm!
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Injectors will stay "wide open" past a certain idc% and they basically turn into fire hoses lol. I would still say any fuel shortage issues will be fuel pressure related.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 30 2015
    Sacramento, Ca
    On the 179mm?
    It's going to be a furnace without every trick in the book for cooling. Iats after a gear or two will shut down the fun real quick!
    Nov 16 2015
    DFW
    Quote Originally Posted by BlownOne View Post
    He never got low rail pressure codes
    Nov 16 2015
    DFW
    But the width of that "pulse" factors in... Doesnt it? What he found was that the time it was a "fire hose" was too short
    Jun 28 2016
    US
    An extremely small dry fogger of nitrous would work much better. Not enough to actually boost power because of it, but enough to give you a cooler intake of air and also cool down everything in that intake tract up until right before the engine ingests it. You'd plumb it right after the filter or even within the intake box if you have it. The idea is to mimic the car sucking in cool winter air, not a shot of nitrous. Like I said, the fogger has to be really small and you'd have to play around with it and figure out what works best and to what point.
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    I run the AEM meth kit with an iabed meth plate at the TB and didn't see lower iats until I switched over to the 1000cc/min nozzle. The middle sized one (500cc/min) helped some but soon as I switched to the large one all knock was gone and iats delta in a 1-4 pull decreased by 10 degrees. I also have a HE and this is on the 183mm. I haven't tried race file yet but might today.
    Nov 16 2015
    DFW
    Quote Originally Posted by 613B6 View Post
    Where did you buy the plate?
    Nov 16 2015
    DFW
    Nevermind... Found it
    Jun 12 2015
    CA
    Where did you find it?
    Nov 16 2015
    DFW
    Iabed industries sells them
    Jun 06 2016
    Florida
    Do you have a link? I can't find the Iabed meth plate.
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    Nice info
    just to check are u running on 93 octane on 183mm?
    thanks
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Feb 25 2014
    Texas
    I currently run an APR pulley with a JHM 179 full e85 with no issues and I'm in Texas as well (directed towards Grumpy).
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Nov 16 2015
    DFW
    Quote Originally Posted by AudiS4B8 View Post
    Same EPL tune? What ethanol content? My local buddy has the EPL tune with the APR pulley and was never able to run above E70 without having codes. Since adding Meth he is running E82-E85 without any issues.
    Feb 25 2014
    Texas
    I don't have an ethonal analyzer, That's next on my mod list. But I'm guessing e70-75 based on reviews of the station where I fill up.
    10.65 @ 129mph
    Jul 29 2009
    Quote Originally Posted by lowjonathan View Post
    Nice info
    thanks
    Yes 94+meth on a 183mm. I have a bigger pulley coming in shortly to try out now that I got my IATs where I want them with a second nozzle in the intake pipe.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Nov 16 2015
    DFW
    So your running 1000cc on the Plate and how much in the second nozzle?
    May 11 2014
    United States
    Do you guys have a link to that iabed meth plate?
    Current: 2018 Audi Exclusive Nogaro Blue RS3 w/Unitronic Stage 1+ E85 ECU and Stage 2 TCU, Water/Meth Injection, Black optics, Tech, Dynamic, Drivers Assistance, RS Design Packages, Carbon Inlays, Carbon Mirror
    Past: 2014 Black S4 DSG/1999 Eclipse GSX
