Results 1 to 20 of 20
    Active Member One Ring S6BlueJacket's Avatar
    Jun 03 2016
    2014 Jeep Grand Cherokee Summit
    Ashburn, Va
    Baseline Dyno Graph
    Hey guys and gals. Finally got a legible copy of my Dyno results from last month. Figured I'd share them with and see what everyone's thoughts are.
    The highlights:
    Max Power: 410.39
    Max Torque: 449.24
    Run Temp: 90.76 Degrees
    Run Humidity: 38%
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Excellent power. If you add let's say 15% drive train loss the car is pushing way more than the factory advertised! And with better temps numbers would have been even better!
    Senior Member Three Rings luv2sleep's Avatar
    Jun 12 2012
    Good info! With a tune or not?
    Jun 03 2016
    Ashburn, Va
    Stock 2015 S6. Audi has always been very conservative on their stated HP and TQ numbers. Most 2013-2015 S6s Dyno around 480HP but Audi stated 420.
    Sep 28 2009
    suburb
    These mean at the wheel right? How does one figure out what the crank is?
    Cool post op
    Jun 19 2016
    Houston
    Quote Originally Posted by flyfishing View Post
    Cool post op
    The 420/450 quoted HP is at the crank.
    Jun 03 2016
    Ashburn, Va
    Yes....the Dyno numbers are at the wheels. The general consensus for an AWD car is 15-20% driveline loss.
    Veteran Member Three Rings MVcycleart's Avatar
    Feb 03 2013
    B7 S4 Avant - SOLD:C7.5 S6 - SOLD:B8.5 S4 - SOLD:B9 RS5 SB
    Gainesville, VA
    S6, i am looking to do a couple dyno runs when my 93 octane tune comes out from EPL. How was IAP? Did you call and schedule for the run(s)? Shoot me a PM with any details as i have a couple extra parts i would like to get some numbers for a few people. Thanks.
    B7 RS4 Avant Clone - Complete conversion with all the fixings
    Other: 2015 Mclaren 650S Spider: MSO, Akra, HRE, Velocity Tune
    2004 MV Agusta F4 1000S
    PAST - B7 S4 Avant, B9 RS5 SB, C7.5 S6, B8.5 S4, E-tron SB
    Get busy living, or get busy dying!
    Sep 19 2014
    Newcastle
    I wonder if US models make more power than UK ones as we usually see 373whp on the hub dyno
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Quote Originally Posted by pez81 View Post
    no, that is just a higher than normal numbers I would say.. not that this car actually makes more power than normal, just this particular dyno run is "high". just a measuring device, best for before and after comparisons. I will be getting on a dyno next tuesday for some stock pulls before tuning, will post up mine as well
    Sep 19 2014
    Newcastle
    Quote Originally Posted by MikeDwerks View Post
    Ah thats what I thought. Do you know what stage 2 WHP usually is on a lower reading dyno? Im debating whether to just add a cat back for some noise and a bit of extra power even though it's not much or just go stage 2 with downpipes on the stock exhaust.
    Jun 03 2016
    Ashburn, Va
    They did three pulls and they were all within 5 HP of each other. The graph I posted was the middle of the three. I plan on doing at least APR ECU and TCU tunes soon at NGP in Lorton....possibly downpipes at the same time. Of course, I will post the after Dyno shortly thereafter.
    Feb 14 2014
    Oklahoma City
    IMO I would just do down pipes and leave the rest of the exhaust stock. You should get a noticeable change in tone and be adding a part that will actually make more power.
    Feb 14 2014
    Oklahoma City
    Quote Originally Posted by S6BlueJacket View Post
    Great to see members doing before and after dynos. I will have a baseline dyno and after with EPL stg 1, will be interesting two compare our results between the two
    Jun 12 2012
    Pretty impressive numbers for stock.
    Anyone know if I can just install any upgraded down pipes to go stage II or do I have to buy from the tuner (ie. APR down pipes for APR tuned cars)?
    Feb 14 2014
    Oklahoma City
    Quote Originally Posted by luv2sleep View Post
    As long as they are I the same general design and about the same inside diameter as the tune was developed for, would not matter what down pipe you ran ( and I believe all the ones available fall in that category) Companies that offer both down pipes and tunes might make it fiscally advantageous to run their both products but don't confuse that with compatibility necessarily. In the end I would still ask that question to the company you choose to use just to cover your bases
    Jun 03 2016
    Ashburn, Va
    Without the before numbers, you never really know if you're getting your money's worth for your upgrades. I look forward to the comparison, Mike.
    Jun 12 2012
    Good to know. Thanks!
    Feb 14 2014
    Oklahoma City
    Was on the dyno yesterday. see thread below for results
    http://www.audizine.com/forum/showth...ock-Dyno-Pulls
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Im pretty sure Dynojet has bigger horsepower #s then a Mustang Dyno. It seems the Mustang Dyno #s always come back way lower than Dynojet. But as long as you test on the same Dyno before and after you are good to go! Good stuff buddy.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
