Results 1 to 14 of 14
    Established Member Two Rings DGS6's Avatar
    Mar 14 2014
    Southern California
    H&R ETS Module D4 S8
    Having trouble installing this on a 2015 S8. It was plug and go on my S6, but on the S8 I am not getting any movement. I thought it might be a bad module, but I plugged my old module in (S8 needs a different wire harness) and still no adjustments. Anybody have any idea's?
    I had car lowered via VAGCOM the 17mm prior to installing H&R. Not sure if this is part of the issue?
    Thanks.
    24 RSQ8 Sat Silver- Mods under way
    Gone 2021 RS6 Floritt-Black Red-Carbon-3M Stealth-Vossen Evo5R Black-Ceramics-Turbo Upgrade-Custom ECU / TCU-Meth system-CSF Coolers-Cete Lowering & Memory-Akra-Sway Bars-Matrix enabled-Eventuri-Maxton V1-2 10" subs-Stealth Hitch-968HP 7368rpm-772Tq 3978rpm wheels
    Gone soon 2022 SQ7 Glacier White-Black w/ Gray-Black Optics-B&O-Eurocode-Vossen Evo3 Black-Cete Lowering-APR-APR Intake-Uniden R7-Est 560HP 600tq wheels-Est 700HP 750tq crank
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    Where are the connections for the ETS model on the D4? I looked in the trunk side fenders and didn't see any matches.
    Mar 14 2014
    Southern California
    From inside the trunk, pull off the cover for the back of the back seat. Most are driver side, but one connector goes to passenger side, making the harness different for D4 vs C7. I thought it was under the rear seat cushion, it is not. There is a fuse panel and a bunch of other stuff on the back seat...now I understand why we don't get 60/40 folding rear seats.
    Feb 12 2004
    Albany
    I don't have the A8 specific instructions and none of the plugs seemed to fit neatly or at all. Do you know what I should be swapping?
    Mar 14 2014
    Southern California
    Quote Originally Posted by nadroj81 View Post
    That looks like the wire harness for the S6/S7... All but one connector goes to left / driver side. The black brown long lead goes right side up where the brown goes. I will take a pick later but look to the left. ETS part numer should be a dash 2 on the label.
    Registered User Four Rings mike@vossen's Avatar
    Jan 23 2013
    Miami | Atlanta | Kingston
    Quote Originally Posted by DGS6 View Post
    Thanks.
    Weird, we have it on our 2015 S8 and it was plug and play....I'll see if I can take pics tomorrow.
    Feb 12 2004
    Albany
    I have a 2013 A8, i have the 28951-1 part number which should be correct according to the application guide.
    Feb 12 2004
    Albany
    I figured i would update this since I did get it installed. On a 2013 A8 you have to remove the fuse panel (5 bolts). A few bundles of wires are zip tied so you need to snip them. The Wabco unit you connect the yellow and purple plug into are behind the fuse block below the big silver box. The brown plug goes where the black plug is (above the 2 brown ones on the bottom right).
    The instructions I was given by H&R were not entirely accurate. (They said a black 32 pin with purple lever - This was the black plug instead).
    Jan 23 2013
    Nice! I just snapped this pic, excuse my dirty car washing hands lol
    Established Member Two Rings Fast05stang's Avatar
    Jun 02 2014
    2018 S6, 2005 Ford Mustang GT, 2009 Jeep Cherokee SRT8, 2018 S/C Mustang GT, 2018 911 GTS
    San Jose, CA
    Sorry if this is a stupid question (no one else seems to be having this problem), but I just got my H&R module today, and it says to remove the 5 nuts covering the fuse panel. I have a 2013 S8, and my rear panel looks just like the one in the pics above. Those definitely look like fuses to me, but there definitely weren't 5 nuts to take off. Are they on the left/driver side (i.e big silver box will a black plastic cover thing??). If so, I only see 4 screws that could come off. Can any of you guys help me out? Or maybe post a pic of the finished install?
    Jun 02 2014
    San Jose, CA
    Update. I removed the 5 nuts from the panel, but I'm having a hell of a time actually removing it to get to the back connectors. Any tips/tricks?
    Feb 12 2004
    Albany
    You actually have to cut several zip ties that are holding cable wraps and preventing the fuse block from moving. Eventually you can pull some of the fuse panel town the open trunk area. I definitely got some scratches on my hands, trying to manipulate the connectors in. You probably won't be able to actually pull the 5 connector ecu past the fuse block.
    Jun 02 2014
    San Jose, CA
    Did you unplug any factory fuses/cables to remove the black front panel? I got the zip ties off, but this baby isn't going anywhere. There's literally no way to get behind it at the point.
    Feb 12 2004
    Albany
    Quote Originally Posted by Fast05stang View Post
    Not the fuses, a few of the boxes i disconnected to help make room. I will PM you my phone number, i can probably help better in real time if you'd like to call me or something.
