Results 1 to 11 of 11
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Car randomly won't start sometimes
    The car always cranks but sometimes it just won't start. I can bump start it by pushing it and then dropping the clutch and it runs completely normal. I was thinking a crank position sensor but hen it should run bad too. Any opinions?
    Jul 07 2009
    Alberta, Canada
    Does it not start after getting up to temp? Like run to the grocery store, come out, and it won't start?
    Need more details.
    Oct 27 2012
    Lamborfeetes
    Washington
    Yeah pretty much. It always starts when it's cold. It made me think of the possibility of the coolant temp sensor going bad. It should of thrown a code though.
    Jul 07 2009
    Alberta, Canada
    Speed sensor on the trans most likely.
    https://www.ecstuning.com/Audi-B5_S4...Sensors/Speed/
    Oct 27 2012
    Lamborfeetes
    Washington
    Yeah that's what I originally suspected (as said in my first post).
    Jul 04 2012
    Woodbridge, VA
    You should able to watch it change in vag com while you try to start it. If no change, there's your issue
    Established Member Two Rings chris120391's Avatar
    Aug 30 2010
    Las Vegas
    Crank position sensor, same exact thing happened to me last week. Once it started it ran perfectly fine. But every so often would not start. Crank position sensor fixed it.
    01 A4 tqm Gt2871r - SOLD
    01 S4 k24'd E85 stock block - Current
    Oct 27 2012
    Lamborfeetes
    Washington
    Ordered a Bosch CPS. Will install and report back.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    When you have the car running hook
    up vagcom & look at your live data for
    CPS, coolant temp, speed sensors, MAF
    values etc.
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    you are getting nothing when you turn the key?
    You should check with VAGcom before throwing parts at the car, but you may also have a bad starter (dead spot on the motor coil) or possibly even your ignition switch. I replaced both, but in my case, it was the starter.
    Oct 27 2012
    Lamborfeetes
    Washington
    I already logged everything and everything checked out. The car isn't throwing any codes except for some weird code having to do with the crank position sensor. I know it's not the starter because it's turning over the motor.
