The latest stunning release by the expert engineers at ECS Tuning. The 6-Speed Adjustable Short Throw Shifter provides up to a staggering 47% throw reduction that is combined with a 75mm shift knob height adjustment range.
A gorgeous piece to look at in itself, the ECS shifter's beauty is surpassed only by its precise construction and advanced functionality.
Constructed primarily from billet 6061-T6 aluminum for structural strength and weight savings, the unit is designed to withstand the hardest of shifts and retain the use of your OE shift knob.
- Up to 47% reduction in throw
- 75mm of shift knob height adjustability
- 6061-T6 Aluminum body
- 304 Stainless steel shift rod
- Spherical 440c Stainless steel, self-lubricating, precision ground, heat treated, PTFE lined shifter bearing
- Nylatron NSM shifter plates for superior wear and noise resistance over Delrin blends and even brass.
- Retains OE shift knob
- Made in the USA
Reduce throw & height
Fitment:
Audi B6/B7 A4/S4/RS4 2002-2008 (6-Speed Only)
Be sure to check out our -----> Installation PDF <-----
Jason
