Results 1 to 4 of 4
    Sep 19 2012
    Saint Clair Shores MI
    No clutch pedal and no leaks
    So my clutch has been acting up for a few days now and now I have no pedal at all. I used to be able to pump it up and then it would be fine until the next morning. Today I'm sitting on the side of the road and can't get any pressure at all. No visible leaks and I have a full reservoir. Any ideas? Replaced the clutch slave about a year ago
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Possible bad seal in master
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by redline380 View Post
    X2
    What you are describing, having to "pump" I back up, combined with no external leaks is guaranteed clutch master.
    Slave can only leak to the outside. Master can have the plunger seal leak which will just relieve pressure but not leak externally.
    Sep 19 2012
    In case anyone was curious, the clutch master took a dive. I ended up getting sold a new slave too. The tech pretty much insisted on it, so now the clutch should be good to go until I have to change the clutch... which should be a while from now.
