Results 1 to 17 of 17
    Jan 04 2014
    US
    Benefit of Secondary Air Pump / SAI DELETE
    Hi folks,
    Searched thousands related thread,
    Can't find out any answer of this.
    Could someone help ?
    Thanks.
    B6 04' A4 1.8TQ 6MT
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    the benefit of the SAI pump is that you are heating the cat up quicker, on a cold start condition, which will cause less emissions to be exhausting through to the muffler. also I'm sure because of this...the cat lasts a lot longer.
    The benefits are emissions related. not performance related.
    I hope John comes in here and explains his reasoning for keeping the SAI pump but I'm sure he's so annoyed with trying to explain the benefits.
    my view. unless you have a test pipe, or a big turbo...keep the SAI pump.
    2003 A4 1.8T 5-spd Frankenturbo'd.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    As jpull mentioned, diagnosticator will just copy and paste a response I'm sure he has saved on his desktop, because this comes up weekly!
    For a colourful thread on the topic, see here.
    I'm an amateur, but I know this about SAI:
    - On startup an intake cam/exhaust overlap causes unburned fuel to be dumped into the exhaust stream. The SAI pump work in conjunction with the "combi valve" and injects air into the exhaust stream during this startup phase (90 seconds, I believe) to aid in burning the fuel dumped there, therefore, getting the cat up to temperature faster and making it more efficient and last longer and, of course, significantly reducing emissions.
    - Since the whole system runs only on startup, I fail to understand the argument of some people who remove it for "performance". It makes no sense to me, unless they rev their engines to redline within 90 seconds of starting them cold. After that, the system just sits there.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Jan 06 2009
    Benefit is freeing up space in the bay / weight reduction.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Established Member Two Rings noldevin's Avatar
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    I am only removing mine because it failed, and would rather spend the money on a tune to write it out permanently than on a new pump that will probably just fail again. If yours is still functioning I see no reason to remove it unless you have a test pipe, in which case it is useless.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Quote Originally Posted by noldevin View Post
    I have all my SAI stuff from when I removed it for my BT setup if you did want to replace the pump.
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Quote Originally Posted by ADCS View Post
    And removing a part prone to breaking. Both my Audi's and 1 VW have had the SAI pumps go. Only part on the engine to fail aside from wear items.
    I think they got a little better as the generations went on, but its still a weak point reliability wise. And its fucking expensive to fix. The pumps are like 400 bucks and to get them installed is multiple hours because of the way z germans weaved the fucking pipes about the engine.
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Quote Originally Posted by KHARDa4 View Post
    I appreciate it, but I've already ordered my Motoza Stage 1+ tune and sent him my stock ecu file. Might as well make some extra power out of the situation :)
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    if you code out the Secondary Air, might was well code out the Cat too.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Jan 04 2014
    US
    Thanks guys for the great help even though it is like a weekly/monthly question LOL
    I got my testpipe on and the reason why I am going to remove the pump is
    Maybe I will get the CXRacing inlet kit
    I am not sure it is really BOLT ON, or need to remove the SAI pump to free up some space
    B6 04' A4 1.8TQ 6MT
    Aug 13 2015
    NS
    I don't believe there's much to be gained by switching from a factory airbox to a CAI. There are even some logs floating around the forum threads to show that the OEM airbox is quite good.
    Besides that, I'd be concerned about sucking up air that close behind the bumper grills. A good water splash could soak that cone filter if you're missing bottom splash guard etc. Just my $0.02.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by eljay View Post
    I'll just leave this here: Clicky click®
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Would love to see how low his filter actually was....
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    I drove with that intake for about a year. At first I liked the sound, but once I put an Exhaust on I couldn't hear it anymore. Put the stock airbox on, the car feels much better now. Never had any issues with the filter getting wet, but i was running a belly ban.
    Jan 04 2014
    US
    holy sxxt, that's cause a big trouble
    B6 04' A4 1.8TQ 6MT
    Dec 25 2004
    Earth
    If your car get annual state emission inspection...it wont pass inspection with the SAI removed/broken. Unless your tuner tweeks the ECU...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jun 24 2014
    NC
    In NC you can have one readiness monitor fail. I run an AEB head so I don't have SAI. Passed inspection with no problems. You do get a check engine light like every 200 miles, but if you clear that about 75 miles before inspection all of the other readiness monitors pass.
