Results 1 to 11 of 11
Thread: 2003 A4 shaking
    Established Member Two Rings leightonw's Avatar
    Aug 12 2016
    Soldotna, Ak
    2003 A4 shaking
    I'm trying to figure out why my car shakes, it only really does it when I'm cruising at around 45-60 mph slightly letting off the gas while still maintaining speed. I can increase speed gradually and the shaking stops, steering wheel shakes and a slight vibration in front end. I've replaced the lower rearward control arm, both upper control arms, outer tie rod end, and wheel bearing on passenger side front. The rims and tires are in great shape and drives straight down the road. It has the CVT transmission with a 1.8T, 132k miles. Could a snub mount cause that vibration when slowly easing off the gas, motor mounts aren't leaking and alignment is spot on?
    Sent from my SM-G925I using Tapatalk
    Aug 12 2016
    Soldotna, Ak
    Established Member Two Rings alexb6t's Avatar
    Mar 11 2016
    quebec canada
    Transmision mount ! I had the same problem..
    Sent from my SM-G903W using Tapatalk
    Mar 11 2016
    quebec canada
    This one
    Aug 12 2016
    Soldotna, Ak
    It made the steering wheel shake when slowly letting off the gas? What were your symptoms????
    Mar 11 2016
    quebec canada
    Same symptoms as yours but if your steering is shaking i would recommend checking the CV's !
    Aug 12 2016
    Soldotna, Ak
    I just replaced the drivers side, it was a lot worse when I purchased it, didn't think I'd make it home, 60 miles away.
    Veteran Member Three Rings B6_A4_Kid's Avatar
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    My b6 was doing this for awhile, and it ended up being misfires. See if it vibrates when you let of the gas. If it doesn't it's probably misfiring
    Aug 12 2016
    Soldotna, Ak
    I dont have any misfire codes and runs smooth revving and easing off gas at a standstill
    Aug 12 2016
    Soldotna, Ak
    The only code thats on is the P0420 due to a test pipe on it with no rear 02 sensor spacer.
    Mar 11 2016
    quebec canada
    Quote Originally Posted by leightonw View Post
    Have you check the passager side ?
