Results 1 to 29 of 29
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Highway fuel consumption
    Just wondering what the average mileage people get on the highway is??
    I use about 8 litres / 100km (~29mpg) and wanted to know if this is what most people get while cruising at 65mph on the highway in 7th gear.
    Cheers
    Jul 14 2013
    British Columbia, Canada
    How do you get into the 7th gear?
    I get about 9L/100km or 26MPG at that speed.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    The DSG is "7 speed s-tronic" ya dill
    Jun 06 2016
    Florida
    No idea. My cruise gets set to 80+ mph, and there are some spirited runs with that almost every day. The best I've seen is 22mpg.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    When I was stock I would see 26mpg. Nowadays I avg 12-15mpg lol
    Jul 11 2016
    2001 BMW R1200C, 2001 SeaPro w/115 OP
    Englewood FL
    2015 S4 - Car is usually reading 25.2 - 25.8 highway with the cruise set to 86, including a blast on the pedal every once and a while.
    Edit: Running in Comfort mode, in Florida in 87+ degree weather.
    '15 S4 | Sepang | Alu Kreuz | CR-15 | 034 DP ECU/TCU | XLR8 196.5mm | HPFP | Merc HX | 034 rear sway | 034 Full inserts | Dinan Coilovers | ECS Kohlefaser Luft-Technik |
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    26 mpg at 70 to 75 mph with occasional speeds to 80 mph with AC on , calculated by miles driven / gas used. stock . Driving in D.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Most I got was 418 miles from a tank on 14gal which equated to 29.87 mpg. That's is 90% highway and using some hypermiling techniques and lots of discipline. Probably will never happen again as I love spirited driving. I just wanted to see what the car could do. My AVG is 24-26 with couple WOT a day and 21 when I drive very spirited.
    Apr 10 2016
    Reading/PA
    My avg is about 22, with a few WOT/90% spots per day, but if I'm on a long highway road trip, I've seen 28mpg for a tank doing 78-80
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    There are probably already 30 separate threads about MPG's...
    The average MPG is 20 for this car => http://www.fuelly.com/car/audi/s4
    The best I've ever gotten on a road trip after 5 years of ownership is 24mpg. No - I was not cruising at 65 though...
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    I'll do around 8L/100km too if I'm gentle (around 110km/h)
    Translation
    I'll do around 29mpg too if I'm gentle (around 68mph)
    City though its more like 10-11L/100km :(
    Murdered B8.5 S4
    Build Thread
    Established Member Two Rings Sailingtime's Avatar
    Mar 18 2015
    2003 Vw Jetta GLI VR6 BDF Turbo
    NYC ��
    [QUOTE=Dirt;11828961]No idea. My cruise gets set to 80+ mph, and there are some spirited runs with that almost every day. The best I've seen is 22mpg.
    I'm glad I'm not the only one with low MPG's 22-23best most of the time 19-21mpg Garden state Parkway (aka raceway) driving daily.
    2015 6Spd Daytona, Tech, Sport Diff, Napa , B&O, Black Ops, Carbon Inlays.
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Just got back from a 400 mile road trip. I averaged 28 MPG cruising at 80 mph. 2013, DSG, 91 octane, running the AC.
    Aug 22 2014
    bloomfield,ct
    [QUOTE=Frinkferta;11829507]Just got back from a 400 mile road trip. I averaged 28 MPG cruising at 80 mph. 2013, DSG, 91 octane, running the AC.[/QUOTE based on trip computer or miles travelled divided by actual fuel used? Trip computer is NOT accurate.
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    On full highway I generally am 25-27 mpg. Best I ever had was coming up the Columbia Gorge in Oregon with one hell of a tail wind and got 30 mpg.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    From LA to SF. 25.8 mpg cruising at 75mph in 100-105 degree weather, ac on.
    Car is stage 2
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    APR Stage 2. Best I ever got was 33.1mpg on a single trip (105 miles total, mostly freeway). I was REALLY trying for good MPG though.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    The last road trip I had, cruising at 75mph, I got 30.7mpg highway.
    Senior Member Three Rings BAHNSTORMER's Avatar
    Mar 26 2010
    Waukesha, WI
    Calculated 26mpg on my last road trip that was mostly highway & running 75mph whenever I could.
    Daily driver: 2012 S4 P+
    Phantom Black Pearl Effect / Sports diff / Alcantara / S-tronic / MMI Navi + / B&O / 19" Peelers / Carbon Atlas inlays / advanced key / rear camera / Supercharged badges
    Previous Audis: 1984 4000S Quattro // 1989 200 Quattro // 1994 S4 // 2005 S4 // 2010 A5 3.2
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    Quote Originally Posted by Frinkferta View Post
    This. 93 oct.
    Apr 10 2016
    Reading/PA
    Quote Originally Posted by creativecody View Post
    I'm using this as ammunition to sell my soon-to-be wife on a tune. "See Honey, I'll SAVE money on gas!!"
    Jun 22 2016
    West Chester, PA
    I drive ~9-12 miles one way for work and I average around 18-20 on the tank with 93octane...which is oookay. But on longer drives with a speed of 65-75mph, I get a very decent 28-29mpg.
    2016 S4 Sepang Blue Premium+ | Black Optics | B&O Tech Pack | Sport Diff | ADS | Black Nappa
    CTS Intake | Alu Kreuz | EBC Red Stuff | 034Motorsport Dynamic+ Springs | CR-15 | Vorsteiner VFF-103
    Build Thread
    Jul 20 2012
    Quote Originally Posted by dls11b8 View Post
    HAHA.....I approve! I can provide a photo of the mpg on the dash if you need proof.
    2013 S4
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Everybody has already answered, but I average around/just shy of 30mpg as long as I'm cruising at a set speed. From my parents' house to mine (suburb to city), I average around 31mpg (the suburbs are at a bit higher elevation and the city is on the lake). The same trip used to get like 37mpg with a 2013 Honda Accord Sport.
    BTW, the question of using AC keeps coming up. The truth is, modern cars actually get around the same mpg with the windows up and AC on as they do with the windows down. Modern aerodynamics are drastically affected by open windows, so there's actually no benefit in trying to drive with the windows down to avoid using the AC.
    Aug 27 2012
    Earth
    [QUOTE=jygesq;11829553]
    Yup - calculated.
    Jul 14 2013
    Quote Originally Posted by mlavelle92 View Post
    ...the sarcasm definitely flew past your head.. lol
    Jul 05 2016
    Ontario
    I can get 7.8 L/100km with lazy highway driving (80 km/hr back roads) doing the speed limit - ish. 10 to 11 around town is typical. 9s for typical mixed spirited driving on the commute. Running 91 e10.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by hotleadsingergu View Post
    I've read this, too. However, I've calculated mpg on several occasions with and without A/C on the same trip, in similar conditions. I've always gotten about 2 mpg less when using the A/C vs having the windows down. But, when I drive with the windows down I drive with the front and rear passenger windows down halfway. Not all 4 down. I've found that produces good airflow without being obnoxious. I wonder if that creates less drag (and better mpg than using A/C in the process?)
    May 12 2016
    Interesting, wasn't expecting so many responses!
    Looks like 7th gear (if you've got it) at 65 mph (~100 kmph) on highway cruise control averages 25-30 mpg (which I can hit if I try)
    I'm getting around 10-15 mpg per tank (almost all city driving) which is still far below the average, which seems to be 20 mpg... I used to have an '08 S5 which would get me the same milage
    EDIT: Car has averaged 15 mpg over its lifetime of 15k miles, pretty fu*king terrible. Somethings wrong with my car though ha.
