Results 1 to 12 of 12
    Aug 18 2016
    Texas
    Squeal from engine bay??
    Neef help guys. I do not have an audi shop in town tontake this to so im trying to get an idea of where the noise us commingvfrom. Started aboutbavwrrk ago. Was only when driving for about 30-60 mph then went away wgen slowing. Jus started when stopped in the garage. its aldo intermittent tiday it did not do it until late, however it seems to be getting worse. Any ideas?
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Probably something with the serpentine belt, bearing, idler pulley.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Aug 18 2016
    Texas
    Sorry was trying to post vid
    http://youtu.be/B4IAu0vE0Cg
    Here is the vid. Seems to be atound the pcv area slso changes with shift?? I tried lubing the belt with new change another her vid dhortly
    Aug 18 2016
    Texas
    Wow sorry about all the typos on the original post. Doing this from my cell. Thanks for any info guys.
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I had a similar noise and thought it might have been the idler pulleys but further examination of the Pcv block off plate solved the issue. I replaced the entire plate, there's a check valve in there that can deteriorate over time. There's an easy way to check by blowing through the breather hose at one end. I don't remember if it's supposed to blow through or block though
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by supple View Post
    In the stock PCV when you blow in it is supposed to block the air.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Aug 18 2016
    Texas
    Ill give this a shot thanks
    Aug 18 2016
    Texas
    So i tested and it did block the air so dont know. but a while back i was getting some pcv errors on the vag when i replaced a thermostat. They cleared and did not return. I did the idel engine and pull oil cap check and the idel drops bit not much so Im going to go ahead and order the part to replace it since it seems to be a quick easy job anyway. Hopefully that will be it. Any other ideas on what to check while i wait on shipping peeps :).
    Aug 18 2016
    Texas
    The strange thing is ot will do it then go away for 1/2 a day then come back for 2-3 days
    Aug 17 2013
    Rossford, Oh
    It was hard to tell from the video where its coming from but it sounds like a metal squeal rather then a belt.
    I would check your belts to make sure they're not missing teeth on the timing and that the acc belt isn't worn down.
    PS. With the pcv you can actually open some models up and see the diaphragm (or the rubber part in there) and see if its torn. The circular part pops up, just be careful to not loose anything inside and note they way it goes in there before removing any springs. (not hard to do).
    Aug 18 2016
    Texas
    Quote Originally Posted by yeoj112689 View Post
    Success!! Pcv valve was it. thank you so much guys!!! great to have my car back to how it is suppose to be!
