The spec sheet suggests the sport suspension "offers 20mm lower ground clearance in automatic and comfort modes." My assumption is the full range is lowered by 20mm, but is the range actually adjusted, or is it the same hardware just programmed differently?
If I find an A8 with sport suspension, will the maximum ground clearance be reduced relative to the standard air suspension?
Thank you, Chris
