Results 1 to 2 of 2
    Mar 05 2012
    Omaha, Nebraska
    Miltek non-resonated fitment issues?
    Hey all,
    I've recently installed this system, and ever since I've had knocking over certain bumps/throttle positions. I've now adjusted this exhaust three times, first time I noticed that the pipes were contacting the bracket below the driveshaft under the rear seat area. I removed the bracket, clearances the pipe with a slight dent. After that still was knocking, and again jacked it up and ensured the system was "canted" forward for thermal expansion (exhaust hangers). I was able to get another 1/4 of forward movement on the system and finally just entirely removed that bracket under the trans tunnel as it was just knocking on it like crazy.
    I thought that was going to be the end of it, but I can only assume I now have it knocking around off the rear subframe/differential as it is right there and while underneath I can get it to knock on that with massive movement. I don't believe the exhaust is moving around that much. I'm rather disappointed that I've paid this amount of money and am having these fitment issues... Wondering why they didn't V-band this system to ensure no errors slip fitting the system.
    Has anyone else had similar issues/solid fix on this particular system??
    Thanks,
    Steve
    2010 Audi S4 DSG Meteor Gray; Daily; USP intake/Miltek non-res W/Black Oval tips; Dual Pulley (3.139) GIAC/DSG Tune/APR CPS 11.884 @ 115.9
    Oldies-10 Blue A4 Stock,00 Nogaro Blue 6MT, 04 Moro Blue S4 6MT, 00 A4 Avant w/tip
    Apr 07 2006
    Aussie in Singapore
    Did you ever get that knocking fixed?
    I too have exact same problem after installing it (bought used). Thought it was knocking at the rear diff too as it's so close.
    Rob
    Street - RS3 FL Sedan Daytona Grey APR stage 1+ | APR TCU | Wagner IC | IE intake | Forge turbo inlet
    Track - EVO X RS JDM | HKS Stroker kit | OS valves Cosworth cams | BorgWarner EFR8374 turbo 2.0bar | direct port meth inj. | AST 5300 3way & 16kg springs | 18x11” A050 M | carbon doors | Chromoly subframes | roll cage | Motec M150 | ceramic hubs | 2,920lbs
