Results 1 to 6 of 6
    Aug 18 2016
    westchester NY
    1999 A4 2.8- No start/crank and No fuel. Please help!
    Hey Guys,
    I have 1999 Audi A4 2.8 quattro. Manual.
    Got it as a daily. Its been a headache ever since. Long story short... went to the store, I come back, unlock the car, I got in and the alarm went off.. so I got out - locked and unlocked and it shut off the alarm.. I get in the car to start and nothing. No start or crank. I turn the key to on> start and just blank.
    Its been a week trying this. I have searched the forums, tried and Googled everything related to this problem but I can't seem to figure it out. It is driving me nuts. Here are some things Ive done:
    - At first, I Jumped the battery ( thinking it just died ) Still nothing
    - Checked All the fuses inside, Still nothing
    - I thought it may be the clutch switch - this sensor is expensive! so I by passed it. Still nothing
    - Fuel pump relay works and click ( also replaced it with a new one )
    - I got a new ignition switch, replaced it, still nothing.
    So the starter isn't getting power.. and neither is my fuel pump?? I checked this by removing the fuel rail and I also don't hear the pump priming. I am thinking its something with the Anti-theft or immobilizer?? cutting power to pump and starter? I kind of ruled the immobilizer out because I DO NOT have a bilking light on the dash AND people said that it would crank the car, start and then die.No?
    I am honestly lost at this on what else to try... I thought it could be the starter and was going to push the car.. but if i don't have fuel, whats the point? Im thinking its an electrical glitch? Anyone??? Anyone experienced such a thing? I saw a few similar threads on this topic ( no start/crank ) but all of them can hear the fuel pump working.. unlike in my case.
    All the help and opinions are greatly appreciated it!!
    p.s- Anyone wants to buy the car. PM me!
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    Have you hooked it up to VCDS?
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Aug 18 2016
    westchester NY
    Quote Originally Posted by Pringle420 View Post
    I checked the OBD for codes. I have 4 codes. but none of them are related. an o2 sensors, evap stuff like that. None of the codes were serious. It was running fine before. The light was always on. I don't have a VCDS or VAG-COM... =/
    Aug 18 2016
    westchester NY
    Anyone know what could cause a no Start and No power to fuel pump? Could this be some sort of Anti Theft?
    Aug 18 2016
    westchester NY
    Anyone??? I have checked all fuses and replaced the fuel pump relay but still no sound/power going to fuel pump...
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    My guess is clutch switch, the car needs to see a clutch signal to send power to the starter, the fuel pump on pumps when it sees a crank signal (rpm) How did you bypass your clutch switch?
