Results 1 to 11 of 11
Thread: CV Boot Clamps
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    CV Boot Clamps
    In the middle of changing the CV boots and can I use these clamps below
    Or is the one with the crimp necessary? Because I don't have that crimping pliers.
    "Beep beeeep bloop boop" - R2D2
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Screw clamps will be fine. Just don't over tighten them and damage the boot. Hell, I used zip ties on my rear boots years ago and they still work just fine.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    You can get away with using diagonal cutters to pinch the ear. Of course it's better with the actual tool to get an even pinch, but I've had relative success with diagonal cutters.
    For what it's worth, I fairly recently picked up this clamp pinching tool:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It's so cheap, that I think every DIY Audi owner should buy it!
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Oct 14 2011
    Norcross, GA
    CV Boot Clamps
    Dammit the screw clamps are a bit wider and just ruined the pinch clamp ughh
    Going to walk to the auto store tomorrow to find some new ones.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    I don't have the proper tool so I usually crimp them with shoemakers pliers / end nippers, otherwise sidecutters.
    the actual tool is basically dull end nippers i think...
    Oct 14 2011
    Norcross, GA
    CV Boot Clamps
    Ha ha success! ...and now to do the passenger side
    Oct 14 2011
    Norcross, GA
    Finished the passenger side today. Feels really good to cross this one off the list.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by Willënskraft View Post
    Where did you buy your clamps?
    Mar 05 2013
    CA
    That inner joint socket design seems to have a propensity for the boot to slip off, even after clamping, because it's not even force all around, evenly applied on a circular surface.
    Rather, some parts of the boot are thicker rubber, so the clamp tightening is actually just squeezing the rubber, and not clamping it.
    It may seem tight at first, but then will slip off after driving.
    Hopefully that does not happen. It seems more likely on more extreme CV angles, such as when lowering a non-sport 3L automatic. Which uses the same inner CV design.
    Manuals don't seem to have that problem. Maybe their inner design is different, and at less of an angle. More of a straight shot to the wheel.
    Just warning you.
    Not sure if this means you just have to tighten the clamp a little more.
    I have that same tool, and when trying to put force through it, it seemed to get loose and then eventually broke. The metal looked porous and not very strong.
    Stuff always looks cool until you actually install it back on the car and drive it for a while to see if it works or not.
    I've never tried a cutter tool, or screw clamps. A ziptie might work on the inner, because it's already sitting there with a tight sealed fit, holding in grease.
    The large clamp is what's more important, because it has to keep the boot from falling off.
    Quote Originally Posted by MetalMan View Post
    Looks like a better quality tool option, with no failure-points since the design is fairly simple.
    Maybe I should've bought that one instead then, and ordered online.
    The 'Lisle clamp pliers' were the only thing on the store shelf at the time.
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by dalmation53 View Post
    Clicky
    And NAPA auto parts, but you have to buy the CV boot kit to get the clamps.
    Established Member Two Rings MRCT's Avatar
    Sep 19 2016
    2015 Renault Kangoo Maxi 1.5DT
    Melbourne, Australia
    Nice to know fletch.. now i just gotta grease them.. i won't zip tie them but hose clamp them.. as ill get the proper loops
    Sent from my SM-G935F using Tapatalk
