Results 1 to 12 of 12
    May 23 2016
    Raleigh NC
    C7 A6 A7 alignment camber adjustment
    So, I need some help.
    My wheels are being delivered Monday. Before I put my them on with new tires, I need to adjust my camber.
    As far as I can tell there isn't a kit available for the A6 C7 model that allows the camber to be adjusted.
    There is a kit from SPC that is sold by AWE for the A7 with adjustable upper control arms. Odd thing is, the A6 isn't listed as fitment compatible.
    But if I look up the part numbers for upper control arms for an A6 and cross reference them to an A7, then the numbers match.
    Does anyone have any experience with adjusting the camber?
    And before you ask, I have called and spoken with reps from 3 companies about this and no body has a solid answer.
    All help and ideas are welcome.
    Thanks
    Sent from my VS990 using Tapatalk
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    i remember seeing one member had adjustable upper control arms on his C7 A6.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    unless something has changed in the last 6-12 months, there was not adjustable control arms available for the C7 A6, went through all this before when I had my A6 on coilovers. I even ordered what some said would work even though it was not technically listed for our car, and it did not fit
    Jan 30 2015
    Irvine/CA
    found it.
    jrsAudiA6 had Adj. upper control arms listed in his sig, maybe check with him.
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B and O sound system, 20" Sport Pkg, KW variant 3 suspension, Alcon Mono6/380mm front brakes, S6 rear brake rotors(356x22mm) and caliper carriers.
    Adj. upper control arms, Eurocode Front and Rear sway bars & Alu Kreuz front brace, GIAC Stage 2
    - Michael
    May 23 2016
    Raleigh NC
    Thanks for the info. Anyway we can find out what he used?
    And what arms did you try that didn't work?
    Veteran Member Four Rings Not A Good Idea's Avatar
    Apr 26 2012
    Hmmmm...
    Li. Ny
    I'm going to guess he used the Spc ones.
    Mar 02 2009
    State of Confusion
    Quote Originally Posted by Not A Good Idea View Post
    Yes. He bought the SPC from AWE tuning
    May 23 2016
    Raleigh NC
    Thanks guys, I just ordered the SPC ones. I'll update when they come in.
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Quote Originally Posted by Adrenalin Junki View Post
    Nice do you have a part #?
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    May 23 2016
    Raleigh NC
    http://www.awe-tuning.com/make/audi/...ontrol-arm-kit
    This should be it, it's listed to fit the A7 not the A6, just fyi. But I'm going to try.
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    I replied to your PM a few minutes ago and yes those are the ones that should work as I indicated in my PM. I have had no issues with these control arms in the 3+ years I have had them on.
    FYI: I noticed AWE also sells a subframe alignment tool. They imply it is needed when installing the adjustable upper control arms. The tech that installed mine did not touch the front subframe therefore no subframe alignment was needed. Of course a complete wheel alignment was performed after the installation.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    May 23 2016
    Raleigh NC
    Thanks for your help.
