Results 1 to 4 of 4
    Jul 05 2016
    PNW
    Rear Diff and Snub Mount
    Hey guys, looking for a DIY write up or some tips for replacing the rear differential mount on my c5 allroad. Put in 034 tranny mounts a few weeks ago but now the clunk/jerk is back when shifting in lower gears, so I figure I'll just replace all the mounts until it's fixed. From what I've read it seems pretty straightforward...?
    Also, is there anyway around putting the allroad into 'service position' to change out the snub mount?
    Both mounts are headed this way in the mail so I'm looking for some advice.
    Thanks in advance!
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    No you need to remove the core support to fit the new tighter fitting snub. You dont have to remove it all the way, just enough to work in the snub mount location and not have to drain all your coolant.
    Rear diff is easy. It is literally a swap out and doesnt take long. The hard part is getting the bushings out of the diff carrier (mount located behind / above diff)
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Jul 05 2016
    PNW
    Quote Originally Posted by LakeTahoeQuattr View Post
    Ok, so do I have to remove the bumper to do the snub? Also, do the bushings in the diff carrier need to be replaced at the same time as the rear diff mount? Thanks for your help
    Active Member Two Rings JoelKnauber's Avatar
    Apr 13 2016
    Wisconsin
    I did the rear diff carrier mounts from 034 last week. It was kinda a big job. The 3 allen head bolts that go into the diff are probably rusty (mine were) and kinda soft. I had to cut one. I also have a big press and it took quite a bit to get the old mounts out after I had the carrier off the car. But that's because I didn't want to burn them out. I've heard that's how some people do it.
    Side note... I just replaced the carrier mounts for now. Red is track density. I haven't really noticed anything different.. I did "window weld" on the front diff mount and that actually seemed to make more of a difference than the rear. Just food for thought.
    IMG_9911 by MxJoel165, on Flickr
