    Established Member Two Rings ben0069's Avatar
    Apr 07 2010
    merc 280 ce auto, 123 body shape.
    saundersfoot
    Allroad 2.5 tdi rear diff help/ advice.
    HI,
    I have a 2004 allroad tdi 2.5 v6 bau, manual 01e gearbox, I also have a 4;1 centre diff, I am getting a lot of thudding only on slow turns from standstill both ways, I had this before I changed the centre diff too, and have changed oil. The part number is 01R 500 043 R and the code is ENX on the diff, the ratio is 35.8. Do I have to have exactly the same diff or can I choose from ENY,GKH or FCE codes all of which have different ratios ?
    thanks
    ben
    May 16 2008
    South Texas
    Must be the same
    Apr 07 2010
    saundersfoot
    Thanks Scotty, have you considered doing upgraded rear diffs at all ?
    May 16 2008
    South Texas
    Other than a wavetrac diff there isn't much to upgrade.
    Apr 07 2010
    saundersfoot
    I'm looking at one from shokan parts same code ENX they say the one they have came from an auto do you know if that makes it incompatible ?
    thanks
